Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 11-30-2004, 12:16 PM
gamache gamache is offline
wheel hop
I have a 1990 Integra, 1.8L with a turbo. The front wheels hop under power. What is the least expense way to solve this problem?
Old 11-30-2004, 02:47 PM
BullShifter's Avatar
Re: wheel hop
least expensive? don't accelerate so hard and it will even save you money . . . . .
Polyurethane motor mount inserts are the cheapest may to cure some of the problem, or you can fill your orginal mounts with some gew, I do have a website link at home.
traction bars would be the ideal way - http://mmrusa.com/dsrcrossmember.htm
Edit: here's that website - http://importnut.net/motormount.htm
Old 11-30-2004, 11:16 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Re: wheel hop
Haha you and I think alike I was going to say the same thing before I read your post.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 12-06-2004, 11:05 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: wheel hop
Would that happen if you were to get a stickier set of tires or would that make the wheel hop worse? My Euro TA's hop sometimes under hard acceleration and don't even chirp. I thought it was the clutch slipping at first, but realized i had shitty tires.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-06-2004, 11:26 PM
Civic Mod
Re: Re: wheel hop
It would make matters worse. In most cases the motor mounts and/or suspension bushings are shot. My car is almost 5 years old and I got some really bad wheel hop because my driver's side motor mount (which is hydraulic) was gone AND my bushings were bad. Once I replaced those the hop wasn't as bad.
On my car I could replace 5, but I only did the lower driver's side & passenger side AND the rear one.
Autocross Help Page
Buy my Civic parts!
Old 01-20-2005, 11:30 AM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
Just curious, where would the front crossmembers mount to leave room for headers and such?
Old 01-21-2005, 12:44 AM
Re: wheel hop
It mounts where the stock crossmember is.
