Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-30-2004, 10:52 AM
aha2001 aha2001 is offline
Question 1999 Infiniti I30 keyless entry
I am looking for instructions to reprogram a 1999 Infiniti I30 Keyless entry remote. Any help with programming instructions is appreciated.
Thanks
Adam
Old 02-12-2005, 04:49 PM
bugmenot bugmenot is offline
Banned
Re: 1999 Infiniti I30 keyless entry
My 1998 worked with these instructions. But I could not figure out how to get two remotes working. When I programmed the car with one, it lost the program for the other.
1. Get in the car and close and lock all doors. 2. Put the key in the ignition and remove it completely 6 times in 10 seconds. If done correctly, your flashers will blink once and you will enter programming mode. Turn the key to accessories mode and press any button on your remote within 5 seconds. The flashers should illuminate again briefly. 3. Turn the ignition off and remove the key. 4. Unlock and open the door. Exit the car and shut the door. 5. Try your remote out.
Old 02-12-2005, 05:34 PM
Banned
Re: Re: 1999 Infiniti I30 keyless entry
I found where Infinman posted these instructions that I verified work with my two remotes and 1998 I30.
1.Close and lock all doors
2.Insert and remove key more than six times within 10 sec.At the last insertion leave key in ignition.{hazards should flash twice.all remotes stored are now erased}
3.turn key to ignition accy.
4.push the lock button on your remote once.{hazards should flash twice}
5.to program an additional {up to four} remotes, unlock and lock drivers door manually{with knob not elect. switch}
6.push lock button on additional remote.
repeat step 5&6 for each additional remotes
Note: if you open the door at any time during this procedure it will cancel the enabling state.
