Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-30-2004, 01:46 AM
crabby760 crabby760 is offline
What's A Good Nitrous Set Up ???
i have a 96 honda civic ex with the d16y8 vtec motor stock except for these mods
cold air intake
dc 4-2-1 header
apex ws 2 exhaust
zex street/strip comp cam
aem cam gear
act clutch
act lightned flywhel
b&m fuel pressure regulator
apex vafc controller
mugen spec obd1 ecu
obx underdrive crank pulley
obx ps/alt pulley
what other modifications are good to use if i want to run a 65 or 75 shot wet nitrous oxide kit ?
and if anyone know's how much hp my motor would be putting out please feel free to tell me thanks
Old 11-30-2004, 03:37 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: What's A Good Nitrous Set Up ???
fuel pump, larger injectors, Colder spark plug stay away from zex plugs, make sure that "mugen spec" ecu isnt advancing timing too much.
Timing + Nitrous = BAD
edit: doh I see you said wet kit, you could always get larger injectors to be safe might help your setup out while your not spraying. Dont go too large.
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-01-2004, 11:45 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
What motor do you have in that 91 hatch, and what mods?
Old 12-02-2004, 02:07 AM
I have a crx now I used to have a hatch.
It has an LS, ebay intake and a thermal cat back, and a 50 shot, and a broken motor mount. - yes I know the time is slower than expected, it's a high 13 sec car just didnt get enough practice in with the nitrous.
without nitrous it ran 14.7 @ 92-93mph
1991 Honda Crx Si
Old 12-02-2004, 02:33 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
the 2 things i would worry about first is like civicHBsi said hwo much does that mugen chip advance your timing and second get rid of that obx underdrive crank pulley.
idk if that 75 shot is too big for that y8, the 65 shot might be pushing it. i would take out that mugen chip and run a stock ecu. should get something that will retard your timing when on the bottle. and of course supplying enough fuel so you dont lean out
Team Lonely Drivers
Old 12-02-2004, 11:30 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id fix the motor mount first. i guarantee you pick uo time in the 1/4 just fixing that.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-02-2004, 06:09 PM
Yea the car is off the road right now im hiding alot of wiring and making it look real clean and also trying to drop some weight and fixing the mount...the car will also be run with a different setup.
1991 Honda Crx Si
Old 12-03-2004, 02:28 AM
S13wanabe's Avatar
It's nice to see people using the ls motor. It's so cheap and much faster than a b16. Nice. I have a LS/Vtec with PR3 pistons. I love it.
