Go Back   Automotive Forums Car Chat > Mercedes-Benz > SLK
Old 11-30-2004, 12:30 AM
i drive nothing i drive nothing is offline
Send a message via AIM to i drive nothing
Question slk 230 kompressor?
what is a kompressor?
im 15 and a half. but my uncle has a kompressor. and maybe i will own it later. does anybody know how it works? If you do, can you give me details? thanks.
first post, new member -jay
Old 11-30-2004, 05:24 AM
blindside.AMG's Avatar
blindside.AMG blindside.AMG is offline
Send a message via AIM to blindside.AMG
Welcome to the forums, Jay.
Kompressor is basically German for "super charger". A super charger attached to the engine and it's job is to force more air into the cylinders which affectively produces more power for the engine.
Here's a good article from Sportruck.com on how they work:
To understand how a supercharger works, you have to think of the engine as a giant air pump. The motor’s four-stroke cycle first allows the pistons to draw air in through the carburetor, the intake manifold and the intake valves. The air is then compressed by the piston while all the valves are closed and ignited by the spark plug. The resulting explosion forces the piston down in the power stroke. The final stage of the four-stroke cycle is when the piston comes back up and forces the spent gases out of the exhaust valve.
In theory, a denser air charge (also mixed with fuel) will create a more powerful combustion explosion inside the cylinder, thus creating more downforce on the piston which translates into horsepower. Increasing this air charge is where the supercharger comes in. The mechanically driven supercharger force-feeds the combustion chamber a denser air/fuel mixture. This mechanically increases the compression ratio by forcing a boosted (pressurized) air/fuel mixture in the combustion chamber. The denser charge will increase dynamic cylinder pressure upon ignition to create more power.
Type A & B Personalities
Mechanically driven superchargers can be classified into two distinct types: basic air pumps and true compressors. While that cool-looking monster 6-71 may look like a giant air compressor, it’s actually just an air pump. The 6-71 is a classic Roots-type blower which dates back to the 1880s when the Roots brothers designed it as an air conveyor for mine shafts. General Motors later adopted the design in the 1930s as a supercharger for its GMC diesel engines, using it mainly to pump out exhaust gases. In general, Roots blowers have a two- or three-lobe rotor design, depending on the size of the case. They can move mass quantities of air which stacks up inside the intake manifold to create positive pressure, or boost. Not only do they look cool sticking through the hood, but they have higher discharge temperatures than other designs.
The second type of supercharger utilizes a more efficient design which actually compresses the air as it's drawn through the unit. Some examples of centrifugal blowers are those from Paxton, Vortech Engineering and, to some degree since the air is compressed inside the unit, the Whipple Industries screw-type supercharger. Turbos also fall into this category.
Centrifugal superchargers are basically belt-driven turbochargers (as opposed to exhaust-gas driven), with inlet air drawn to the center of the blower where the high impeller speed converts this air velocity into pressure. The high turbine speeds are generated by internally overdriving the input shaft which is also overdriven by the external drive pulley. Turbine speeds can approach 40,000 to 50,000 rpm on these types of blowers, with normal boost in the 6 to 10 pound range for street engines.
One of the most popular blowers for late-model Chevy street trucks is the Whipplecharger from Whipple Industries. The bolt-on blower is basically a twin-screw compressor that shares a case similar to a Roots-type supercharger. By design, it's an axial-flow supercharger that compresses air as it moves between the twin screws of the blower. The screw supercharger offers potential advantages over less efficient, non-compressor designs in that the outlet temperatures are normally lower.
No Free Rides
As with everything in life, nothing is free. All belt-driven superchargers need horsepower to run--sometimes as much as 20 percent of engine’s total. The good news is that the additional horsepower created by the blower will more than make up for power loss. The other concern with supercharging deals with the law of physics. High school physics taught us that when air is compressed, heat is created. The more efficiently a supercharger compresses air, the less heat added to the intake manifold. And we all know the cooler the intake charge, the denser the air and the more horsepower available.
Blower efficiency is measured by the discharge air temperature at a given pressure. For example, Blower A might have a discharge air temp of 180 degrees at 6 pounds of boost, while Blower B might have a discharge temp of 195 degrees. Blower speed also comes into play here. The higher the speed, the more heat generated. Supercharger manufacturers refer to a blower's efficiency in terms of adiabatic efficiency: how well it pressurizes air into an engine. For example, a Roots blower typically has an adiabatic efficiency of 50 percent, while a screw-type supercharger and centrifugal blowers can see up to 75 percent. Thus, higher boost levels do not necessarily mean more power. Intercoolers can lower intake temperatures by pushing the compressed air through a radiator-type device--but at the cost of boost pressure.
Old 11-30-2004, 07:49 PM
Re: slk 230 kompressor?
wow. i dont get it. but. okay.... explain. in easy words. im not that crazy over cars. i just know. lil basics. im planning to learn a lot through this forum. : ) people here are so nice
