Old 11-29-2004, 10:14 PM
savvyandsaved savvyandsaved is offline
Unhappy Car Won't Start
I have a 91 camaro rs 6cyl automatic. I went in to work fine, came out after 10 hrs and the car wouldn't start. When this has happened in the past, it's been the starter, replace it and all is well. NOT this time, the car still would Not say anything, no clicks, I could only hear the fuel pump. I've replaced the battery, starter, ignition switch other related parts and testing. Then a friend summized that there is no reason that the car is not starting by all other measures. He first got under the car and somehow made the starter jump, so we knew the starter was fine, we reverified everything else, then he ran a wire, he said by passed the ignition, then tried starting it....now the car is trying to start, but still won't quite catch? He's not sure which direction now that of trying to find a short and where to look or I've been reading the posting here and now other possibilities, like the vats, something about the service light being on and or flashing and what that means? Can anyone say more on this issue? Thanks in advance!
Old 11-29-2004, 10:48 PM
89IrocZ-28Camaro 89IrocZ-28Camaro is offline
Send a message via AIM to 89IrocZ-28Camaro Send a message via Yahoo to 89IrocZ-28Camaro
Re: Car Won't Start
could be your vaccum
Old 11-29-2004, 11:49 PM
Question Re: Re: Car Won't Start
My vaccum..what does that mean..please say more?! I don't understand?
Old 11-29-2004, 11:51 PM
Re: Car Won't Start
is your car fuel injection or carb?
Old 11-29-2004, 11:53 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Re: Car Won't Start
Sounds like the VAT system is totalled f*****.
I haven't ever had anything similar to that happen to my maro' but I do have to click my ignition about 5 times before she'll crank to start.I was told it could be the built in Solenoid on the starter , due to the heat it obtains from the engine , it wears it out faster. I haven't actually looked into it more than that because it hasn't died completely on me yet so no need to.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 11-29-2004, 11:56 PM
Re: Car Won't Start
yeah thats what im saying it could be the vat.. or it could be his key security.. like i say it sucks to have those security system on the key grrr
Old 11-29-2004, 11:58 PM
Fuel injected.
Old 11-30-2004, 12:00 AM
92rs25th's Avatar
Re: Car Won't Start
Vacuum leak shouldn't stop if from cranking. The starter runs off electricity not vacuum. Has nothing to do with it.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 11-30-2004, 12:01 AM
Can you say whether it is wise to consider replacing the vats as far as cost or what?
If it the security system within the key, what are my options?
Old 11-30-2004, 12:02 AM
92rs25th's Avatar
Re: Re: Re: Car Won't Start
New key , 5 bucks.
Vats system = Hahahah!!!!!
Run some codes on her before replacing anything. Save some money and time.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 11-30-2004, 12:04 AM
I have another question for you....how wise is it to by pass the key security system...I'm thinking that this would make my car more vunerable to theft and or will that effect other things....what do you think?
Old 11-30-2004, 12:10 AM
Re: Car Won't Start
all u gotta do is wait til the security light goes off.. but the lease it should go is about 3 minutes.. if it went over 3 minutes then its your security system.. but if its not it, then its something inside your motor. gotta have the computer sensor check before you mess with anything..
Old 11-30-2004, 01:20 AM
Thanks very much for that info....I'm going to test that! I appreciate it much....stay up!
Old 11-30-2004, 02:11 PM
FlawedByNature FlawedByNature is offline
Send a message via AIM to FlawedByNature
About that key issue....
My '92 was broken into before i bought it. (it doesnt run yet) And i dont have a key for it yet. But i need to "have the whole car run through the machine at a chevy department to get the right codes for the security system so i can have the right chip built into my key." Well, thats what im told. And i could care less if my car has a security system or not, (for now at least) so just to get it running, what should i replace? (Again, i dont care about the securty system for now, i just want her to run.)
Old 11-30-2004, 02:22 PM
Unhappy Re: Car Won't Start
Someone attempted to steal mine also, I still had my key though, but the steering column was tore up! Yet they still couldn't get the car. I took the car to person that repaired steering columns, he was able to repair the column and I was able to keep the same key and all for $80-100.00 out the door. One thing I understand about the security system is that if it's working correctly, it's just added security and protection for our vehicles! but on the other hand, if it's not working correctly it can be a pain! I hope this helps!
