Old 11-29-2004, 09:52 PM
thetruth4130 thetruth4130 is offline
what to check
got it a couple months ago 89,000 94 metro 5sp, what to check, what are best spark plugs, can 5.25 inch speakers cram into the 4 inch spots some how, i have them sitting around, anyone else have problems with rolling the window up or down, what a pain in the ass to mess with that while your driving, it doesn't lift evenly, easy fix?, thanks
Old 11-30-2004, 12:06 PM
mcalvo's Avatar
mcalvo mcalvo is offline
Send a message via MSN to mcalvo Send a message via Yahoo to mcalvo
Re: what to check
Hey Truthman:
Do a search through the forums. The most of your question had been already answered some time before. I clearly remember the rolling window issue.
Good luck.
MC
Old 11-30-2004, 02:13 PM
Zogboy Zogboy is offline
Re: what to check
use the ones that are recomende in the owners manual.
Take the door panels off and lube the tracks and make sure they don't bind.
Old 11-30-2004, 08:24 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: what to check
check your plastic roller inside the track. seen a lot of them break and just the metal ball on regulator is left
Old 12-01-2004, 11:42 PM
bullpup bullpup is offline
Smile Window Problem...
You might try this quick fix for the difficult window problem...
Roll the window down completely and clean inside the horizontal and front vertical rubber window channel with a damp cloth. Then take a rag with ArmorAll, or some like product, and coat the inside of the rubber window channels as best as you can.
I've had the same problem where the window barely rolls up or down and this completely resolved the problem for many months.
If there is a mechanical problem or part damage, this might not work, but......
Hope this helps!
Paul
Old 12-02-2004, 06:08 AM
SeanMurphy's Avatar
SeanMurphy SeanMurphy is offline
Re: what to check
My 98 HB takes 6.5" speakers all around, and that's what she's got. I went for Fusion FP-652s, and had only a slight problem due to Fusion speakers being generally a little too big for any application because of their massive magnets.
I've also got a Fusion Powerplant 12", w/ 1000W amp, and a Kenwood MP3 headunit. Poor little car runs first in class come the stereo competitions in spring. Last number I hit was 146dB with the single 12. Nothin beats Fusion for price/performance
02 Chevrolet Tracker 4WD
