Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-29-2004, 10:32 PM
off_da_wall4u2nv off_da_wall4u2nv is offline
radiator
i have a 1994 automatic honda integra. i had a radiator leak on the bottom of my radiator, i put some prestone super sealer in it and it stopped leaking but for some reason after about 20 minutes of driving my car it starts to heat up, all the way to the H. anybody know why? it has fluid in it still.
Old 11-30-2004, 12:05 AM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Sounds like the thermostat is no good. CHeck it out. If it locks up it will cause over heat and over pressure ( pop the radiator like a balloon. )
Happened on my 88 B20A SI.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 12-01-2004, 05:05 AM
Re: radiator
well its not the thermostat. i bought a new one and stuck it in. its still overheating. anybody have any other suggestions?????
Old 12-01-2004, 05:30 AM
92rs25th's Avatar
Re: radiator
Then may just be a matter of either the Fan not working or a relay/sensor issue. Check your fan fuse , make sure that's good. Check your fan out with a simple touch of a 12v hot to the main red lead , if those don't work may want to resort to replacing the temperature sensor or fan relay switch.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 12-01-2004, 07:13 AM
Re: radiator
yeah i had a question about the fans. if im not mistaken when you turn the key in the ignition just enough to power the car the fans should come on right?
Old 12-01-2004, 02:34 PM
92rs25th's Avatar
Re: radiator
Mine always did.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 12-03-2004, 12:36 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: radiator
i hope that sealer stuff didnt seal it all the way and block the coolant flow. you can turn on the engine and the fan should come on after normal op temp after about 2 min. i wired in a simple override switch so i can turn both fans on when needed took about 20 min and they still work at the normal times also (and when you say "honda" integra do you mean right hand drive "honda" integra)
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 12-03-2004, 04:38 PM
genkichild's Avatar
genkichild genkichild is offline
Send a message via AIM to genkichild Send a message via Yahoo to genkichild
Re: radiator
Have you flushed your radiator ever? Depending on what kind of fluid you use and when you change it, it can gunk up or crystalize along the inside of the radiator.
I reverse flushed the radiator on my truck and blew out about a litre of solid material. Then again, I did take it out in the desert a lot.
Just another idea ^_^
Old 12-03-2004, 05:30 PM
Mendari Mendari is offline
Re: radiator
Originally Posted by off_da_wall4u2nv
... i put some prestone super sealer in it and it stopped leaking but for some reason after about 20 minutes of driving my car it starts to heat up,...
Doh!
Don't ever use any crazy additives to fix mechanical problems. That stuff causes more problems than it fixes.
It probably gunked up the water jackets around the cylinders. So flush your coolant system with water until you wash out that super sealer.
Old 01-01-2005, 04:57 AM
Re: radiator
well i got it fixed it was my water pump.
Old 01-03-2005, 11:53 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: radiator
Guys do not ever put tap water in your car! Never!
Tap water contains chlorine and that will damage your cooling system. Don't even use it to flush the system.
And yes I was going to say water pump but I am too late lol.
It would not have been the Thernostat because the thermostats in our cars are designed to fail in the open position. just FYI
Old 06-08-2005, 04:36 PM
blex blex is offline
Re: Re: radiator
Im having a similar issue. Already replaced radiator and thermostat. When car is idle in drive it begins to over heat. When i put it in neutral and tap the gas the gauge instantaneously returns to the proper temp. When im driving the car never over heats... just when idle. Is this a water pump issue? And do I have to change the timing belt along with it? And How much will this generally run me.
