Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-29-2004, 09:26 PM
kiltboy kiltboy is offline
Question headlights only work on bright
I bought a 94 v6 2wd used. The headlights only work on bright, the corner lights on front do not work, all the warning lights in the dash are missing blubs and plugs. I pulled the instruments out and moved a bulb to the bright light indicator. It stays on regardless of what position the dimmer switch is in. The headlight bulbs are new.
1. Any ideas related to any of this?
2. Where can I get the bulb plugs (little ones, not 194 bulbs) for the instrument panel?
Old 11-30-2004, 05:15 AM
forest_grump forest_grump is offline
Re: headlights only work on bright
Do the rear lights work???Do you hear an audible click when going from bright to dim???Made sure headlamps work on both dim and bright by unpluging and running jumper wires to back of headlamp??
As far as missing bulbs and holders...can get the holders thru salvage yards or parts house and dealer as last resort...bulbs you can get thru Autozone-O'reillys-Napa or Carquest.
Put all bulbs and bulb holders back in dash and see what you got and repost here with results...
