Old 11-29-2004, 09:04 PM
danameisoj danameisoj is offline
no horn??? need help
i have a 95 gst and when i hit my horn theres nothing. i cant keep driving w/out a horn!!.. if anyone knows what i can do to fix it lettme know. i also tried checking the fuses and i dont have a cover to tell me which fuse is for my horn.
thanks
Old 11-29-2004, 09:05 PM
skyllz skyllz is offline
Re: no horn??? need help
look in the steeting wheel.
Old 11-29-2004, 09:09 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
i'm pretty sure you've tried this already, but did you press the little horn picture buttons on the sterring wheel? i know on my dsm if i press the middle of the steering wheel, nothing happens, i have to press the horn buttons. but why do you need one? your not one of those road rage people are you? scaryyyyy............
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 11-29-2004, 09:24 PM
lol .. thats what i meant by pressing the horn... and im not one of the roadrageing crazy ppl... its just that where i live the majority of the population is over 50.. and they dont look when the drive and cut you off ... almost slam into you when they're changin lanes ... u name it they do it ... so its a lil scary to drive w/out a horn...
Re: Re: no horn??? need help
how do i look in the steering wheel??
Old 11-29-2004, 09:27 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
check your fuses first. then get a test light or voltmeter and a friend anfd check if you have power to the horn. the horn is probably under your front bumper somewhere. if you have power to the horn then you need a new horn they cost like 12 bucks at napa. any generic kind should work they're almost all the same
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-29-2004, 10:10 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i have no horn in my car , just keep the window rolled down and scream....~lol
if all the basic ways like checking the fuses and looking inside the steering wheel dont work. you may actually need to get under the car and find the horn.(behind the bumper cover around the left fog light or the location were the fog light would go)
un plug the harness from the horn. get a voltometer and check the terminals. if you do not get any volts (think its 12v for the horn) or low volts it may be a problem in the wiring, maybe a short. If you get around 12v then your horn simpley went bad and you need to un bolt it and purchase a new one or get a cool musical horn. plug the new one in ,bolt it up and your set.....now if it is a short or falt in the wiring this make take alittle more time tracing the harness back to the fuse box finding the short and replacing wires if needed..
-Jake
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-29-2004, 10:34 PM
i dont know which fuse is for my horn! i dont have the cover that tell me these things... does anyone have a pic or a diagram of the fuse box with lables???
Old 11-29-2004, 11:03 PM
Turbo makes me emo!
yea let me take some for ya real quick
sorry, my dig camera doesnt have flash. anyways, the fuse is in the last row to the right, 2nd down. btw, i have a 98 RS so the fuse box outa look the same.
Old 11-30-2004, 04:00 PM
wow i dont think our fuse boxes are alike at all??? thanks anyways man. well heres a pic of mine .. if anyone can take a look and figure it out lettme know
Old 11-30-2004, 08:16 PM
Turbo makes me emo!
damn, my fuse box is way bigger than yours. i just looked at mine without the cover on, i'm not even gonna waste my time taking a pic. guess they changed the box when they made those slight changes in 97, sorry man
Old 11-30-2004, 08:21 PM
97_3clipse's Avatar
there are two fuse boxes on in the engin compartment (pictured by XeVeNskyLiNE) and the olther under the dashboard on the drivers side(pictured by danameisoj )
Old 11-30-2004, 08:28 PM
Turbo makes me emo!
ohhh, so thats whats wrong, dana, the horn fuse is in the engine bay, not under the dashboard. i checked both of them before i posted that pic, which is the one of the box under the hood.
Old 11-30-2004, 10:41 PM
oh my bad ... mines pics of under the dash... so the horn fuse is in the engine bay.. ok .. well i just changed the fuse and now theres a clicking sound when i tap the horn... i guess i need a new horn
Old 11-30-2004, 10:51 PM
yesa that sound right. the clicking sound is the relay engaging to send power to the horn. your horn probably shorted and blew the fuse and now it doesnt work even with a new fuse. iots not hard to change a horn. just get one from napa and bolt it on.
-1stGenRocks-
