Old 11-29-2004, 07:41 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Need some help fellas
I know this technically should be in Tech, but no one goes in there, and I need help right away. For some reason when I got online earlier this evening my internet was meesed up. It has none of the bars at the top of the screen. No back, refresh, address bar, nothing. And its really a pain in the arse.
Any ideas of what I could do?
Here's a screenshot so you can see what Im up against:
Please Help!
MAKE ART, NOT WAR
Old 11-29-2004, 07:53 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: Need some help fellas
Can I offer an (obvious) answer???
Did you check to see if your "View" menu has changed at all? Also check under the Window menu, if you have one. Yes, they're kinda a "duh" but you never know...
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 11-29-2004, 08:08 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
If you cannot click on any menus, go Control Panel -> Internet Options and go through all the tabs and restore to default.
Run ad aware as well in case it's a browser hijack.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 11-29-2004, 08:41 PM
KustmAce's Avatar
I went to the Internet Options, but there are no tabs I can restore to default. Only "Clear SSL State" and "Autocomplete..."
EDIT: All fixed. I ran a full virus scan and deleted a few files. Then the browser went back to normal. Thanks for your help though.
MAKE ART, NOT WAR
Old 11-29-2004, 09:27 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
In Internet Options, click on the Advanced tab at the top. It's the button on the bottom that says "Restore Defaults". Should put the navigation buttons back in place.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 11-29-2004, 11:05 PM
KustmAce's Avatar
Re: Re: Need some help fellas
No other tabs at the top.
MAKE ART, NOT WAR
Old 12-02-2004, 05:00 PM
If those are the only two tabs you have in Internet Options, sounds like either a browser hijack (I would recommend some spyware removal softare) or Internet Exploder is toast.
Try some spyware/adware removal and see if it's a hijack. If this isn't the case, I would reinstall IE.
