Old 11-29-2004, 07:13 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Axles colors, is it yellow, red, blue, etc?
While back, cv joint was busted so we got an axle from napa and everything was okay. But before that, we'd tryed pep boys and they gave us the wrong axle, didn't quite fit in the hole on the tranny. But the napa fit. Now the colors on the axles are stripes and I've heard that they are different colors. What color stripes should be on the axles? I've also heard numerous things about the 88-89 axles are different than the 90-91, the 88 has different spline count, and the std base 4-speed tranny axles(which I have) are different than the dx/lx/si. Could someone clear me up on this? I've used the search feature, but nothing real big on the colors. I need to know the colors.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 11-29-2004, 10:30 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
I have an 89 std. 4spd and when i replaced the driver side axle it had one yellow stripe. Also if im not mistaken the dx/si one will have multiple colors (not sure what colors though) Hope that helps.
Old 11-29-2004, 11:49 PM
forcefanad forcefanad is offline
Re: Axles colors, is it yellow, red, blue, etc?
as far as i know the only difference on the std model axels is the number of splines on the outter cv joint. i believe they have 23? and all others had 28? not sure if there is a difference between years.
Old 11-30-2004, 06:24 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
its not the number of splines that's different..its the actual size of the end that goes in the hub... std's have smaller hubs...
SOLD!
Old 12-01-2004, 12:01 AM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
my axles have 26 splines and theres also an axle with 23, which i think is for the std
1991 Honda Civic DX Sedan
Old 12-01-2004, 07:13 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
I'm not sure about the colors, but I know that the Si civics have integra suspension, so the hubs are bigger than the others. dx/lx models have smaller hubs and I'm also thinking that the std is the same as the dx/lx. As far as the tranny, all d series trannys that are 5 spd should have the same splines. Auto's have a different spline I believe, not sure on the std.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 12-01-2004, 09:01 AM
marked001's Avatar
Moderadur
Re: Re: Axles colors, is it yellow, red, blue, etc?
si and dx and lx axles are interchangeable.. and hf and std axles are interchangeable... that's the deal.
SOLD!
Old 12-01-2004, 04:56 PM
Shaguar47's Avatar
I've looked up sites on the axles and the have a axle with a yellow stripe and another with a red/pink stripe. Which models do they go to?
Old 12-01-2004, 09:49 PM
4G4D Store's Avatar
Si/EX are different than LX/DX - the outer hubs on the Si/EX are integra, not civic.
Old 12-02-2004, 12:32 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
whered you hear that from?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-02-2004, 07:01 AM
4G4D Store's Avatar
SI and EX have larger brakes up front (integra brakes) stock. Which also means they have integra hubs. You can swap integra front suspension straight across with no problems. So a Si/Ex axles has D series inside and b series outside in a sense. Also, the part numbers for the EX/Si and different from the LX/DX. And yes, the HF and STD are different than the other two. Mind you these are all Manual Transmissions. So, looks like honda has at least 3 different axles for the 88-91 civic manual transmissions.
Old 12-02-2004, 08:44 AM
marked001's Avatar
Moderadur
you are right about the EX... my mistake..forgot about that.. it does have the bigger brakes..but the si/dx/lx all share the same hubs/axles/brake setup..
SOLD!
Old 12-02-2004, 07:01 PM
4G4D Store's Avatar
I thought the SI (90-91, not sure about 88-89) had integra brakes and stuff up front too. I could be wrong, but I thought the EX and the SI had the integra front suspension.
