Old 11-29-2004, 05:50 PM
george536's Avatar
george536 george536 is offline
Question oil light keeps on coming on ????
My oil light keeps on coming on. when stopped at a light.i checked my oil, everything is fine, but it still comes on. The car runs fine its just it annoys the hell out of me. it only does it when i have the brake in once i step on the gas it goes off. but once i stop it comes back on. please help!!! A/T
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 11-29-2004, 06:20 PM
joemathews's Avatar
joemathews joemathews is offline
Re: oil light keeps on coming on ????
It means your oil pressure is low. Stop driving the car before you find out what the problem is. Let it sit for a few hours (preferably overnight), then check the oil again after all of it has drained into your oil pan. You may find that you're low on oil...
It makes sense that the light would go off when you step on the gas because the oil pump sprocket is driver by the timing belt, rpm related.
1996 Eagle Talon
Old 11-29-2004, 07:06 PM
george536's Avatar
i just got an oil change last week. i kind of doubt its that.
-1990 Eclipse GSX
Old 11-29-2004, 07:25 PM
joemathews's Avatar
Hmm....maybe your sending unit is bad? Better safe than sorry, in any case. I would double check the oil level after the car has been sitting a while.
1996 Eagle Talon
Old 11-29-2004, 08:34 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
do you know what kind and weight of oil they used? if they used to light of oil that could also make your oil pressure low
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-29-2004, 08:37 PM
george536's Avatar
i think they used quaker state. but ill check the oil in a while. see if thats causing it. is it bad to mix oils? like if i add pennzoil instead of quaker state.
-1990 Eclipse GSX
Old 11-29-2004, 08:45 PM
nah, its fine to mix oils. its not good to mix syntehtic and nonsynthetic but everything else is fine.
btw quaker state oil suxs
-1stGenRocks-
Old 11-29-2004, 09:53 PM
george536's Avatar
hey i didnt put it. thats what they put. thats what I get for being too lazy for doing it myself.
-1990 Eclipse GSX
Old 11-29-2004, 10:15 PM
Technical_Automan Technical_Automan is offline
Banned
Ya, Quaker State lasts for about a 1000 miles before it gets all sh*tty. Does the car have a light that comes on after 3000 miles to warn you to change the oil?
Old 11-29-2004, 11:24 PM
george536's Avatar
no it doesnt have a light like that. i just checked the oil and its fine. its at like max or something. what would cause it to come on? little oil? too much? something in the oil? im just stumped?
-1990 Eclipse GSX
Old 11-29-2004, 11:25 PM
george536's Avatar
It onlycomes on when the car is warm. when its cold it wont. i have to drive it for a while.
-1990 Eclipse GSX
Old 11-30-2004, 02:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
Oil light comes on at low pressure, I want to say about 5-6 psi. Spec is 11-22 psi at idle. If you take it the dealer or a shop they should be able to put a guage on it and see what it is. HAppened to me once and it was in spec, so that meant the sender was bad. 20 bucks later I was all done. If your car is turbo check the oil cooler as well. Its common to lose a motor after an oil change becuase the cooler cam loose when they change the filter. People really need to start putting what car they drive in the sig...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-30-2004, 04:45 PM
george536's Avatar
it says im not boosted in my sig. lol. so i just go and tell them to check it? what would need to be replaced?
-1990 Eclipse GSX
Old 11-30-2004, 05:42 PM
joemathews's Avatar
Re: Re: oil light keeps on coming on ????
The oil pressure sending unit if that's faulty. If your oil pressure is good when the dealership checks it, then it is the sending unit.
Sounds like this is the case, since you seem sure you're full on oil. You would be seeing oil under your engine or on the driveway if you had a major leak, as well.
1996 Eagle Talon
Old 11-30-2004, 09:58 PM
AF - Advisor
Clever one liners like that are all over the internet, may or not reflect what you actually drive. It's better than nothing though I guess.
Kevin Jewer
