Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 11-29-2004, 05:40 PM
spooky7640 spooky7640 is offline
hi lift jack
im looking to buy a hi lift jack but i dont know how it will work w, plastic bumpers... how do you use it ? i saw that theynow make an adapter so you can lift by the tire... does anyone have any pics or info for me?
Old 11-29-2004, 06:35 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: hi lift jack
No go. The tire sling won't work with the factory 15" wheels, won't fit in the opening between the rear drum and the wheel. Even on larger wheels, you lose much of the jack's travel before the sling even begins to lift the tire, and regardless it's of no use for actually CHANGING a tire unless you bring along something to support the vehicle so you can remove the jack again.
If you have the base-trim 15" steel wheels, you can actually lift by the wheel just by inserting the tongue of the jack into the spoke of the wheel, I've done it. Same problem when it comes to changing a tire, but it's useful off-road for getting something under the tire for traction.
You need a steel bumper and sliders to really make use of a hi-lift. You can lift by a rear hitch, but it's kinda wobbly.
Brent
Old 12-01-2004, 03:25 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Re: hi lift jack
Brent
And "wobbly" is when things can go bad.
Xterra4x4.com and the Xterra Offroad Webring
