question?
allright say i have a 3kgt sl and i wanted to put turbos on it, is there any place that i can get twin turbos for around 1500 bucks? if not would just one realy good turbo be good?
Hey, I found that in the FAQ. Unfortunately, it doesn't appear to be as simple as slapping turbos on there...check out this website for a list of what you need, and then you could price things up. I'm not too sure you could do it for $1500, but you never know...
http://www.3sxperformance.com/faq/tt...partslist.html |
Re: question?
i heard a single turbo conversion is nowhere as good as a twin turbo. also other than the turbos themselves, u have to swap out the pistons for low compression ones, which by that time ur at $1000
Re: Re: question?
You do NOT have to change pistons on a turbo conversion. Plenty of people have daily drivers running 10:1 compression. Also as far as driveability it depends on if you want all out speed or reliabilty if a single suits you better. A single can get you faster but spool time on a large single would suck for a daily driver.
Re: question?
well thats a choice whether u want to change them or not.. but high compresion+boost means ur engine isnt goin to last long at all.. plus i heard the n/a's can only run up to 4 psi of boost. and the tt is 14?
thats the beauty of a 3000 ..... they r built like brick shit houses .... designed for boost and lots of punishment...there is a guy on 3si.org that sells the complete everything for it new from the dealership....
Re: Re: question?
4psi?? Um the stock wastegate is minimum of 6psi. Several people run 10 psi daily driven and reliable on 10:1 motors. Whoever is telling you your info is wrong. It can and has been done many times.
Re: question?
all im sayin is the tt engine has low compresion pistons for a reason
Re: question?
Dosent having low compression help low end torque acounting for the 315 on the VR4 being at 2500? I don't have one but it seems to me that there wouldent be as much net compression at that RPM as on the NA. Don't even know if lower compression helpws torque but it seems like it would for some reason.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Re: question?
Low compession does not help low end torque, it just allows for more power the same final compession ratio.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
