Old 11-29-2004, 05:27 PM
rv-peddler rv-peddler is offline
Help 96 Caravan dies on road, no start
Need help, am out of town.
96 Caravan 3.0 while doing 70 mph on highway, just quits. Will not start. Had Caravan towed to friends house. Where to start? What to check? Any and all suggestions and or help, will be appreciated.
Thanks,
Ron
Old 11-29-2004, 06:42 PM
vipergg vipergg is offline
Re: Help 96 Caravan dies on rod, no start
Thanks,
Ron
Either the timing belt or the fuel pump . Had fuel pump die on me on a 86 lebaron once doing 60 mph , no warning .
Old 11-29-2004, 08:51 PM
Re: Re: Help 96 Caravan dies on rod, no start
I took off the distributor cap, turned the engine over, rotor did not move, I assume thios is not a good sign????
Ron
Old 11-30-2004, 08:01 PM
Cobra_Sam Cobra_Sam is offline
Re: Re: Re: Help 96 Caravan dies on rod, no start
Ron
May not be as bad as you think. Pull the plugs out making the engine easy to turn over by hand, look down #1 to see when the engine is at TDC (top dead center) then loosen and pull out the distributor. The tags on the bottom may have sheared. You will need to remove it to inspect it anyway.
Old 12-01-2004, 05:29 AM
M'mmmmmmm, ok, I'll try that. Hadn't thought of that. I'll do this this morning.
I appreciate all the help this forum gives.
Ron
Old 12-01-2004, 05:55 AM
GTP Dad GTP Dad is offline
Pontiac Guy
If the distributer proves to be OK then the timing belt should be the next item on the list to check!
