parking lights problem
I installed a remote start/alarm on my 04 silverado. Everything works fine except the parking lights don't flash. Everywhere I've looked it says to use a gray/black wire behind the light harness, or at the BCM at the BCM there's 3 gray/black, and at the light harness there is 2. I've only tried at the green light harness. This is what happens... When these two wires touch the parking lights come on and stay on. I tried both seperately, and both together diode isolated. didn't work...
Parking Lights: Gray/Black (-) Green Connector at the headlight switch Anyone have flashing parking lights with their alarm and where are your connections? Also, should I have the output the parking lights be a positive or negative output?? Thank you...
Re: parking lights problem
Well i am by far no expert on this but my brother used to install alarms/stereo's ect and if i remember correctly to have the lights flash or just to be on you need relays ,I did not see anything in your post about relays <shrugs>
**2007 Avalanche LT. ** ![]() 6" Pro Comp lift 305/55/20 BFG A/T KO'S K&N FIPK GENII Flo Pro V force muffler & 4" slash cut stainless tips Color matched front and rear Bowties 3" polished stainless bull bar and Nerf bars |
Anyway, not sure where you got your info. Some of it is correct. This is what you can do.... Parking Lights+ brown + driver kick panel Parking Lights- gray/black - BCM, brown plug, pin B2 Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. You can use either wire but make sure what polarity your RS is on the output. Some are only - but some can go + or -. Others only will work with relays.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
Re: Re: parking lights problem
Re: Re: Re: parking lights problem
