Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-29-2004, 04:37 PM
aabrasil aabrasil is offline
Rotors
Hi firts time to this site hope someone can steer me in the right direction.
1996 chevy suburban 4x4 2500 8600 gvw, went to change the rotors and got into trouble how does the rotor come out?????? Here is what I did took out nut holding front drive shaft, beat on rotor to come off and no luck. How does that rotor come off or do I just need a bigger hammer
Old 11-29-2004, 06:48 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Rotors
The hub and rotor are one assembly. you will have to remove the axle shaft nut, disconnect the jumper for the ABS and remove the 4 bolts that hold the hub to the spindle.
To remove the rotor from the hub you will need to press the lugs out.
The only thing you accomplished by beating on the rotor was warping the hell out of it.
I recommend that you get a Haynes or other repair manual before you damage something.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-30-2004, 11:07 AM
Thanks for the feed back, now that look at the parts it makes since.
I do have a Book on the my suburban and it gives very different instructions on rotor removal.
Is it normal to get some miss information out of these books (maybe another threat later?)
Old 12-07-2004, 10:51 AM
back2life's Avatar
back2life back2life is offline
Re: Rotors
gm merlin knows his stuff! i see alot of incorrect info in the haynes manual . i think chilton is more specific but expensive compared to haynes
