| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
'94 Ciera 3.1L V6 engine idle/running issues
Hello! I've been searching and searching for things, and i've been reading through a Chilton's book I have for that car and I'm at a loss as to what this is. Basically, it appears to jerk or stutter while running and only occaisonally. Say I am on a highway going 65mph and let up on the gas to maintain that speed (I inherited a car without cruise control--fine with me)...most of the time it will eventually seem to jerk or stutter and it won't stop until I accelerate or let go of the pedal.
The feeling is as if you're going over a lot of rocks, only you can feel it in the driver's seat and nobody else seems to. It seems as if I can feel it on the accelerator pedal itself. It only happens occaisonally, and it ALWAYS goes away if I accelerate (even if only a little bit more). I don't see a check engine light or anything when this happens. The car has ~115k miles on it, and around 100,000 it had a rebuilt transmission installed into it because the clutches burned out. We could be classified as experts, but we had someone else install that. You don't have to dumb down any advice .The car ALWAYS starts up fine, and it seems to be idling better than ever now. We recently replaced the radiator and the engine coolant temp sensor and it also received new tires (Goodyear Regatta 2...fantastic choice as well). Someone else in this house said a co-worker told him of a similar problem and replacing the MAF sensor fixed it. Does this sound like the problem is the MAF sensor? It also has another minor problem. When I put it in park and I'm about to turn it off, I noticed that it is as if the engine is revving itself up. It literally sounds like its doing that, and sometimes you can feel the dashboard shake right before it appears to rev itself up. The LED clock and headlights appear to dim for a second after the sound that seems to mimic punching it down a bit. If you punch the accelerator, it goes away, but it also eventually goes back to a normal idle if you just let it do it. I was thinking of maybe putting some fuel injector cleaner in it, but does anyone know what that problem might be? Keep in mind that these NEVER happened before until only recently (~6 months), and they are absolutely consistent as well. It is starting to use up a LOT of gasoline now too, so i'm getting a bit desperate here. Thanks for ANY help you guys can be of. I was searching google for something like this, and automotive forums came up first.
Re: '94 Ciera 3.1L V6 engine idle/running issues
With mileage being what it is I would say you might want to check coil packs. I had one go out about 120,000 and another at about 121,000. While your problem doesn't sound exactly like mine it is quite similar. As far as the bad gas mileage goes, you might want to check O2 sensor(s).
Re: Re: '94 Ciera 3.1L V6 engine idle/running issues
I haven't considered the coilpacks, do you have a general idea of how much that might cost? I'll go check sometime later today. |
Mine were replaced at the dealer and I think they charged around $200 each time
Replace your tps sensor. Make sure your IAC is learned.
I never thought about the IAC/TPS idea, but that makes sense to me. |
Re: Re: Re: '94 Ciera 3.1L V6 engine idle/running issues
I am having exactly the same problem. Did you ever find out what was it? IAC/TPS or coils?
Re: Re: Re: Re: '94 Ciera 3.1L V6 engine idle/running issues
.After that, it idles PERFECTLY at stop lights and no longer misfires. Also, it seems to launch forward with much greater power. Its probably a combination of the double-platinum plugs, better plugwires and clean injectors. On a side note, the coils were all perfectly fine. Occaisonally, the idle is only mildly rough at idle in a park position and not all the time. I suspect that this could be tied to the surging when the car is in park, and I am suspecting the TPS moreso than the IAC. My research findings point more to the TPS than the IAC, if that helps you. |
