Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-29-2004, 03:00 PM
KEVINS87T KEVINS87T is offline
Ac Heater Controls
My 96 Monte Carlo Heater And Ac Are Stuck In Defrost.has Anyone Else Had This Problem And What Is The Cure?
Old 11-29-2004, 03:32 PM
MNMonte's Avatar
MNMonte MNMonte is offline
Do mean the knob is actually stuck, or do you mean wherever you turn the knob it stays on defrost? If you are turning the knob and it stays on defrost you probably have a leak in a vaccum hose. My 94 corsica 3.1L had the same problem.
Old 12-01-2004, 04:26 PM
Re: Ac Heater Controls
DOES CHEVY STIL USE VACCUM OR IS IT ALL ELECTRIC?
Old 12-02-2004, 08:34 AM
MNMonte's Avatar
I'm not really sure. Like I said, my 94 corsica had vaccumm hoses, but I know that they updated alot of things in 96. I have never looked on my 98 monte. So does your heater knob turn? or is it actually stuck in place?
Old 12-02-2004, 02:49 PM
dwalmop dwalmop is offline
The circulation changes are vacuum-electrically controlled. You may have a bad vacuum solenoid control module, which has six colored vacuum hoses going to it. OR, you could have a bad vacuum hose somewhere.
Old 12-02-2004, 02:54 PM
Re: Re: Ac Heater Controls
Originally Posted by dwalmop
it's actually electro-vacuum. I'm guessing from your latest post that the switch isn't stuck in place. Your most likely culprit is a bad vacuum line.
do you know where the vaacumn lines are located under the dash?
Old 12-02-2004, 02:55 PM
they are inside the dash, my friend. You'll have to take some junk apart to get at them. Truthfully, I've never had any of that apart on my monte so I can't tell you exactly. A Haynes or Chilton's may be necessary.
Old 04-24-2005, 09:50 AM
douglass132 douglass132 is offline
Ac heater controls not working
I own a 98 Monte and had the same problem after changing the battery. After removing the batery again , I found the vacuum line that goes to the vacuum storage canister to be broken. After patching the line with a 5/32 piece of tubing, every thing is working.
