Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 11-29-2004, 02:11 PM
byzrd byzrd is offline
6.0 owners
Do any of you use injector cleaner. Is you do, how often.
I just put 2600 miles on the new psd and she's running rough. I have a total of 7600 miles and I'm wondering if this is normal. Thank you in advance for your advise.
Old 01-12-2005, 03:03 PM
GMCMudBogger's Avatar
GMCMudBogger GMCMudBogger is offline
Re: 6.0 owners
Haven't used it but do use diesel additive. What year is your truck?
There is no substitution for horsepower, bigger tires and more lift! [img]
Old 01-14-2005, 08:59 PM
yotermanic yotermanic is offline
Those injectors shouldn't need cleaning. Your filter on top of your engine filters to four microns, anything small enough to get through your filter should pass right through an injector. Plus with injector tip pressures in the tens of thousands of pounds per square inch, you get a free power washing with every injection cycle! I have seen a couple vehicles where a fellow used too many additives and scoured his injector bores. At four hundred bucks a pop, they add up quick. HEUI injectors need the lubrication of diesel fuel. In short, as long as you change filters regularly, no cleaning additives are necessary. Oh yeah, if you're running rough, take it to the dealership, it probably needs a programming update. A new programming makes all the difference in the world on those 6.0s.
Old 01-24-2005, 02:35 PM
It's good to see the replys. thank you for the heads up. I was told by a friend with a 7.3 to use the additive. I havn't put any in it. I had it to the dealer and the flashed the computer for me. seems to be running better now.
chris
Old 08-12-2009, 02:21 PM
COCDIESEL COCDIESEL is offline
Re: 6.0 owners
I have a 6.0 dieselwhen i bought it i was getting 18 to 19 miles a gallon running 80 to 90 mph now im getting 11.9 on the hwy. Can anybody tell me why. What is fashing the computer and will it help me
Old 08-12-2009, 05:24 PM
rhandwor rhandwor is offline
Re: 6.0 owners
Check with Auto Zone or Advanced Auto they will pull the codes free.
Old 08-13-2009, 03:04 PM
Re: 6.0 owners
does the dealership flash or can autozone do it for me
Old 08-13-2009, 03:05 PM
Re: 6.0 owners
and will that get my gas mielage back up. as you can see im new to the diesel world
Old 08-13-2009, 05:19 PM
Re: 6.0 owners
Once you get the codes you have to fix the problem then blank out the code.
Old 08-14-2009, 02:54 PM
Re: 6.0 owners
thanks alot
