Old 11-29-2004, 01:58 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Question Idle drops and dies
This mornig i drove my car a little hard, and all of a sudden i hear a loud pop from the exaust (like a back fire). After that i pull up at a stop sign and the car died! After reaching my school i reaved the car to see if anything was wrong. After reaving it, the idle just dropped and didnt stop where it should, and the car died. Every time i reave it now the car will die. But if i dont reave it, the car would idle just fine. So do any of you know the problem?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 11-29-2004, 05:54 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Idle drops and dies
after reving and then letting off the gas my RPMs drop to about 400 then stabilize at 750.....i would clean out my TB and adjust the idle and play around with the BISS.....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-30-2004, 10:35 AM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
i have the same problem...only when i take my BOV dump tube of the OOV side to hear my BOV...i love that damn sound but when i rev it up..it will drop my rmp's down real low and the car dies sometimes...this morning i had to throw the tube back on cuz it kept dying rite away...why????
Old 11-30-2004, 11:19 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
There are about 2000 threads on this topic already, please use the search button.
To the original poster:
Is it possible that you blew off one of your hoses (vacuum/intake)?? Just a guess.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 11-30-2004, 11:52 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
check your ignition. i had that problem when my plugs when bad. wasn't firing correctly and dispensing unburnt fuel dies at the lights.
then again, it is one of those common idle freaking annoying problem that DSM has. search around the forum, it's been discussed.
06 Charger SRT-8 black.
Old 11-30-2004, 01:15 PM
Killa_DSM's Avatar
Thanks for all your opinons. I was going to change my spark plugs today, so if it fixes it ill post back.
