Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-29-2004, 01:52 PM
1997Sierra 1997Sierra is offline
97 Sierra tranny problems?
Hi guys. I just joined the forum and it seems like a great place. I have a few questions one my 97 Sierra. It has a 350 and a automatic tranny. THe truck has 90,000 miles and has been good to me until a few weeks ago. The tranny in the truck started to shift hard all the sudden. I drove it on the freeway for about twenty miles and then stopped and tried to take off. The tranny jammed into gear between first and second and second and third. I brought it in and the guys at GM said that it was in need of a flush. They flushed it and it was ok for a week then it started again. Not as bad but it is still apparent. I was told these trucks had problems with the valve bodies? I beleive this is the 4L80E tranny. Any suggestions. I am still driving it around and it runs good but the shifts are not what they should be. My Dad has the same tranny in his 2003 Silverado with the 5.3 but they were known to make noise. Any help would be great.
Old 11-29-2004, 06:29 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 97 Sierra tranny problems?
You most likely have the 4l60-e trans in your truck and for the most part they do not make any noise.
The harsh shift may be from a sticking valve. There are some valve body issues with those trucks when they get some miles on them.
I am concerned when trans flushes are done on vehicles over 50k and those with transmission issues.
You may be heading back with a slipping trans in the future.
BTW..have you ever serviced the trans before this problem occurred?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-29-2004, 08:06 PM
Re: Re: 97 Sierra tranny problems?
Thanks for the help! I have never serviced the transmission before in this truck. The flush seemed to help. I think the sticky valve body is the problem. I have talked to others and they have said that the valve body is most likely the problem. Any idea what it costs for a valve body? I do not know if you can buy individual parts or not. Any ideas or suggestions. Thanks again.
Old 12-01-2004, 02:19 PM
MyTOY's Avatar
MyTOY MyTOY is offline
My 97 5.0 had same prob. Slamming into 2nd after
going into overdrive. I found out it's common &
there are valve body bore kits to fix but
too late for mine - needed rebuild. When I had this
prob., turning it off for a second & restarting would
stop the computer from telling the trans. to go nuts.
Also, it wouldn't go back into overdrive in that condition.
Probably why I needed a new T.C. also.
Old 12-01-2004, 09:54 PM
aaamillertime aaamillertime is offline
Send a message via AIM to aaamillertime
So familliar. Mine 97 silverado does the same thing. It started when I had about 80,000. It's been over two years now. I have 131,000 on it. Guy at the tranny shop told me that more than likely it's a valve sticking, I could rebuild or learn to live with it. For $1200 bucks I decided to learn to live with it.
Old 12-05-2004, 12:26 PM
70camaro 70camaro is offline
it may be too late for some but for others try using the max life trans fluid when you flush. mine started doing it too, had it flushed good asap with max life and now it's working fine.
Old 12-05-2004, 07:32 PM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
I just use a good trans conditioner when I replace the fluid and filter every year in mine.
