Old 11-29-2004, 01:20 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Would this work and/or be quick?
I have a rex with a d16a1 (89 teg). The block is cracked but the head is still good. I have a friend with an si layin around but the bottom end needs to be rebuilt. I was wondering if i rebuilt that bottom end on that si block and put that d16a1 head on that si if that would work and be nice.
Old 11-29-2004, 01:36 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Would this work and/or be quick?
Well is it a dohc zc because i doubt a d16a1 is work all the hassle to put in. Mounts dont line up, etc. And the block wont bolt up to a d16a1 head!
Old 11-29-2004, 02:04 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
ya i thought the 89 teg had a d16a6 or a ZC from japan
Travis
Old 11-29-2004, 02:34 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
its a d16a1 which is basically a weak DOHC ZC, i was lookin at this engine in a junkyard but its nto worth the money or time. What you could do is buy a DOHC ZC block and use the head. But i would go ahead and swap in a sohc d series engine or go ahead and get a B. I wouldnt spend any time with the d16a1 unless youre just tryin to get ur car running again. But no you cannot use your head on the d16a6
1991 Honda Civic DX Sedan
Old 11-29-2004, 03:34 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
didnt the 89 teg have a b18a?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-29-2004, 03:57 PM
so you think i should go with a sohc instead of a dual. if i go single im going to go si i think but if i go dual then its going to be a zc or a b16
Old 11-29-2004, 04:04 PM
forcefanad forcefanad is offline
Re: Re: Would this work and/or be quick?
D16Z6 or B16A1 would probably be ur best bet.
Old 11-29-2004, 05:34 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: Re: Would this work and/or be quick?
oh ok go vtec
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-29-2004, 05:54 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
86-89 teg had d16a1, 90-93 had b18a and b17
Team Lonely Drivers
Old 11-29-2004, 10:31 PM
thats why 86-89 tegs are slow and nobody messes with em.
Old 11-29-2004, 11:04 PM
honda_luvr_2000 honda_luvr_2000 is offline
the only good thing out of the D16A1 is the rods and pistons. the rods r stronger than any other d-series rod, and the pistons give about a .5 higher compression than other d-series pistons. only catch w/ that is, the rods changed to the weaker ones in 88, so only the 86/87 D16A1 rods r an OEM upgrade.
on a side note: i've heard the only difference between the D16A1 and the D16A8/9 (DOHC ZC) is the cams, and if u put ZC spec cams in the A1 u'd then have a ZC. however i have not checked deeply into this myself, so if anyone can back me, or knows otherwise, please say so.
