Old 11-29-2004, 01:16 PM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
How do I adjust, if my car is running to rich??
My car has tons of black carbon spitting out the back, I get backfires all the time when I let off the gas, and the car seems way to slow for 95hp!! Is it running with to much fuel?? it also has alot of white smoke at the same time...
How can I adjust, or fix this?? Anyone ever have this problem??
Thanks...
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 11-29-2004, 03:37 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
reset the ecu, pull 10A fuse in the fuse box under the hood for a few sec.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 11-29-2004, 03:57 PM
Re: How do I adjust, if my car is running to rich??
ha, I've done that a million times for other things, whats that gonna do???? anything else??
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 11-29-2004, 04:00 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..try getting a new 02 sensor..there really isnt any way to 'adjust'...per se.
SOLD!
Old 11-29-2004, 04:32 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you can turn your distributor back a little to try and get the car to lean out more. also get the new o2 like they said to fix the a/f ratio back to normal.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-29-2004, 04:43 PM
Re: Re: How do I adjust, if my car is running to rich??
now when you say back, turn it towards me at the headlights, or away from me, to the back of the car????
im gonna try this one!!, and ill have 2 wait till the car cools down, and try it in the dark. ha ha ha
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 11-29-2004, 06:37 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
just had to giggle when i read that.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-29-2004, 07:11 PM
ha ha, yea that is pretty funny!!
but i bet if you drove this car, you would see what i mean...
i messed with the timing a little, ill see tomorrow if it made any difference...
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 11-29-2004, 11:02 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Your High Flow cat. could be causing it to run a little rich
Old 11-29-2004, 11:11 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
well since your talking about how your car is feeling slow werent u supposed to race that maxima or was that someone else?
1991 Honda Civic DX Sedan
Old 11-29-2004, 11:35 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
our cars dont have any sensors after the cat, that wouldnt cause it to run rich. Try doing a good tune up. Plugs, wires, cap, rotor, o2 sensor, air filter, fuel filter, PCV valve, run some sea foam though it. Test your TBS and other manifold sensors. Might also check your fuel return line and pressure regulator, a clog could boost pressure and make the injectors spray more.
Old 11-30-2004, 12:51 AM
sheng sheng is offline
Send a message via AIM to sheng Send a message via Yahoo to sheng
man you have to check the O2 sensor and the TPS this is (throtle position sensor), this 2 sensor control all the fuel flow in th eengine, so try out this 2 things and youll see the diference, about the white smoke, your engine might be burnig some oil, so check out this, cause of this your loosing compresion too................good look
Old 11-30-2004, 02:22 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
sounds too me like this person needs to just forget about the engine and rebuild it.
that much shit pooping out the back means someone hit too many rpms
Old 11-30-2004, 02:48 AM
Forunn Daberator
Thats not competely true, If it was burning oil I'd agree but this sounds like a easily fixable fuel problem
Old 11-30-2004, 07:00 PM
crxlvr's Avatar
to retard the timing would be to tilt the disto towards you if you are standing in front of the car. or from the side, would be a clockwise direction.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
