Tie Rod End?? Perhaps?
Ok...I'll try and explain this...
When I make a sharp turn to the right and then come back to center...just as I get to center I hear/feel a muffled "clunk" on my driver's side front. Then it's gone...a friend said that my tie-rod end is going...is this the case? Opinions? Jason |
Re: Tie Rod End?? Perhaps?
I'd check your rack and pinion bolts also, mine were loose once.
Sounds like a ball joint i'd check them first.
id check the whole shit, but sounds like a ball joint to me also.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
heh, if only it were as simple as something loose that slides around when you make a sharp corner.
Jason that could be a number of things. Lift and support the left front corner, weight off tire. Then grab top/bottom of tire and shake, do the same thing in all direction. If you duplicate the noise look closely at outer tie rod end, lower ball joint, upper ball joint, upper strut mount, control arm bushings(upper/lower)
http://www.binghamtonlife.com/manual...es/91-18-9.jpg |
