Old 11-29-2004, 11:27 AM
timmaytalon's Avatar
timmaytalon timmaytalon is offline
Send a message via AIM to timmaytalon Send a message via MSN to timmaytalon
Engine Questions
I have a 2.0L 4G63 out of my 95 Talon. Someone told me that this is an "F" type engine. What does that mean? They said that it means that is has a larger bore size from the factory than the regular 4G63. Is that true?
Also I am going to rebuild this engine and need to know some specifications. Does anyone know where I can find these? I need bore size, main journal size and things like that.
Thanks
Tim's 95 Eagle Talon TSI 4G63T
Old 11-29-2004, 04:49 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Engine Questions
chiltons.
DSM geek
Old 11-29-2004, 10:23 PM
kjewer1 kjewer1 is offline
AF - Advisor
IT may be a mitsu rebuild. There will be numbers stamped into the block where the oil pan mates up, and colored dots on the crank if its been cut. You will need a FACTORY manual to decipher the "code" if this is the case. But you cna simply measure the bore as well, stock is 85mm.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-30-2004, 02:48 AM
Technical_Automan Technical_Automan is offline
Banned
An "F" type? Well I know what an F-head engine is, but I doubt that's what you're talking about.
Old 11-30-2004, 03:14 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
the "F" means that your engine is a turbo. a non-turbo has a "Y" code. it's just a letter in the vin code to tell which engine you have, that's all.
95 Talon TSI AWD
97 Eclipse GST
