Go Back   Automotive Forums Car Chat > Porsche > General Discussion
Old 11-29-2004, 11:08 AM
86944drum 86944drum is offline
86 944 rear end knocking
Might anyone have an idea what this knocking is?
All of a sudden I am getting a very audible knocking from the rear end after I engage the car in gear and release the clutch and apply tourque to the wheels. The knock increases with momentum but is very inconsistant in it's rhythm. Only when I engage the clutch or drop into neutral does the noise go away. Does this scenerio eliminate the possibility of a CV joint problem? Please tell me it's not the tranny or clutch......actually...it's ok, just give me your best opinions...I'll cry later.
Thank you
Old 11-29-2004, 10:53 PM
83-944 83-944 is offline
sounds like cv joints to me.
http://www.clarks-garage.com/shop-manual/susp-01.htm
that gives some general info plus repair process.
To make you cry: it could also be your ring and pinion in the tranny.
Wheel bearings usually make noises during corners.
It's most likely not the clutch though.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
