Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-29-2004, 10:20 AM
trigger57 trigger57 is offline
Unhappy Fan problem
My daughter has a olds 88 1992 model and the heater blower fan will not cut off. It stay on even if you cut the car off and remove the key. I had to remove the A/C fuse to keep it from running down the battery. Can anyone help
Old 11-29-2004, 11:39 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Fan problem
The blower module has gone bad.
Look in the engine compartment under the plastic cover on the firewall. Under the relays you will find the blower module...fairly easy job to replace it
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-29-2004, 11:46 AM
Re: Re: Fan problem
Thanks I will check that.
Old 12-30-2004, 08:07 PM
jetkeoni jetkeoni is offline
Why would it be a bad fan motor, especially when the fan runs when the key is off and out of the ignition? I would think maybe it would be a relay with a hot lead that would be stuck. What do you think? ........ after rereading your response I find myself at fault. You are right, it is a module, or relay, but as most I can not find the location of that relay on my 92 olds.
Old 12-31-2004, 03:02 AM
Re: Fan problem
Thanks for the help. The blower module was bad. New it cost $116.00 but I found one at a pick and pull salvage and paid $7.95. It works great. Thanks again for all the help I will be checking back here often. Maybe I can help someone one day.
