Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-29-2004, 10:14 AM
kstang kstang is offline
No air flow
Problem with my mustang:
When I start the car it stalls if I take my foot off the gas. I can tell that there is no air flowing into the throttle body.
After a few starts I can hear the air start to flow and then the car runs fine.
Everything is fine with the air intake (it is not blocked). There must be a senors or a valve that is getting stuck and not allowing air to flow in.
What senors or valve controls air flow. How do I replace this part?
Please advise.
Old 11-29-2004, 07:15 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: No air flow
Please advise.
Check the IAC on thre side of the throttle body, it may be clogged, try cleaning it out with carb cleaner or replacing it depending on how bad it is.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 11-30-2004, 07:52 AM
Thanks for the quick reply.
What does the IAC look like? How do I replace it? Does it just unbolt, any special tools required? Also, how much does a part like that cost?
Thanks. You seem to know a lot more about it that I do, and I appreciate the help!
Old 11-30-2004, 10:52 AM
carnut's Avatar
carnut carnut is offline
Re: No air flow
Is the air filter dirty? Sometimes it's just the simple things that cause problems.
I may be a rat, but I ain't no snitch!
Old 11-30-2004, 12:10 PM
not dirty
The air filter is not dirty. I have a cold air intake. In addition, I disconnected the air intake and it would still not suck the air.
However, thanks for the suggestions. I appreciate the reply!
Old 11-30-2004, 03:07 PM
andrewespo's Avatar
Re: No air flow
The IAC is on the side of throttle body facing you when you look at the engine from the front. It is held on by 2 bolts and a sensor is plugged in the bottom, it's clyndrical in shape. By the way whats the year of your stang and the size of the engine?
Old 12-01-2004, 08:36 AM
The year is 2001, the engine is 3.8L
