Old 11-29-2004, 08:54 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
gas milage
I've finally done my tune-up, so I've been checking my gas milage from station to station, and I was wondering what kind of results you guys get. What I do is use my trip clock to see how many miles I go between fillups , and observe how much I have to fill up with. To overcome filling differences between pumps, I keep filling until the pump turns off after a second. Here are 2 of my results:
328 miles/ 17.1 gal -> 19.18 miles/gal
321 miles/ 17.7 gal -> 18.24 miles/gal
Both of those readings had a pretty even mix of highway/city driving. The second one was also hit with standstill idling for over 2 hours at the Sarnia/ Port Huron border in Canada.
Are these good? I remember someone getting ~22-24 mpg.
Old 11-29-2004, 09:46 AM
clariveros's Avatar
clariveros clariveros is offline
Re: gas milage
I would say that those are good numbers fore normal driving, I constantly check my mileage and on a manual 2wd jimmy i get about 18 mpg, with an about 50/50 city/highway mix, i have been able to get 22 mpg but it requires to much grandpa driving, good luck.
Old 11-29-2004, 11:03 AM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: gas milage
my 95 4WD blazer gets about 18.5 city/highway mixed. i cant complain
Old 11-29-2004, 11:30 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
99 blazer
Well those are very respectible numbers....I just slapped a cap and rotor on after 151K on my 4.3L blazer....
Driving mostly highway...I get a consistent 20-21 mpg.....I am pleased as she is getting old...
The truck is all stock, and maintained and up-to-date. Religious oil changes, PCV, air filters etc.....all contribute a small bit to the big picture....
Old 11-29-2004, 12:54 PM
Re: gas milage
my 95 has 183000 and still ticking. im looking to sell it before winter though. want something newer. probably still a blazer. im happy with my blazer's proformance.
Old 11-29-2004, 10:33 PM
wilfie27 wilfie27 is offline
Re: gas milage
I'm getting around 22 mpg with over 165,000 miles, (bought it in 2000 with only 48K) on my 95 but it is only a 2WD. It would probably be better if I didn't have such a hilly drive to work, 28 mi. Just put on some 31X10.5's for the winter, although it is a taller tire it probably takes more hp to turn them thus cancelling out any advantages. I think drilling the holes in my air-box, the 1.6 rocker arms and moving my IAT seem to help the mpg.
Old 11-29-2004, 11:34 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: gas milage
I get between 22-24mpg with my 1995 Blazer 4x4 on the highway in the summer.
In the winter my mileage can drop up to 2-3MPG seeing the cold air is making the engine run richer.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-29-2004, 11:58 PM
Re: gas milage
would 31X10.5 fit on stock blazers? i thought that 30X9.5 was the biggest you can go. im running 235/75/R15 on there now. i want a bigger tire for the snow.i live in mountains in northern new jersey, i need them
Old 11-30-2004, 12:04 AM
BlazerLT's Avatar
AF -Advisor
Re: gas milage
No, they will rub when turning.
Old 11-30-2004, 12:07 AM
Re: gas milage
so if i get some 30X9.5 there wouldnt be any rubbing correct?
Old 11-30-2004, 12:10 AM
BlazerLT's Avatar
AF -Advisor
Re: gas milage
You don't need a bigger tire for snow.
Wide tires actually lesson the grip in snow seeing you are spreading the trucks weigh over a bigger area.
Stick with the P235/75R15's, they are perfect for your truck.
Old 11-30-2004, 12:22 AM
chcknugget's Avatar
Re: gas milage
I like the size of the zr2 wheels. Somethimes our stock wheels seem too small and donuty. Too bad you need a lift to get those in nice.
I also installed the hypertech programming. I got the unit off ebay, and I've been more than happy with it. I've been checking the gas milage to make sure I'm not losing anything and though I'm not done experimenting with it on or off, it has made my jimmy 100% more enjoyable to drive.
