Old 11-29-2004, 07:47 AM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
Question 69 Firebird loss of power
I've got a 69 Firebird that i have just replaced the distributor cap plugs and wires and put dual straight pipes on it ..... but ignore all that it has major power loss... it idles fine and sounds good but will not go anywhere .... it will move slowly but its like it has a chain attached to a huge rock or somethin ... and when i push it to the floor all it does is try its hardest to move but doesnt move much
what can fix this?
Old 11-29-2004, 09:39 AM
CreepingDeath94 CreepingDeath94 is offline
Does it rev up but just barely move? Check the tranny fluid level. If the level is fine, see what color it is...it might be something in the tranny slipping.
Old 11-29-2004, 08:22 PM
sixt8bird sixt8bird is offline
You dont give enough info. Does it rev up in neutral? Did it run good before you did the work?
Old 11-29-2004, 08:33 PM
wilson05's Avatar
re
ok the fluid is fine and still red as a cherry
and it did the same thing before i did the work to .... theres the rest of the info thanx if you can help lol
Old 11-29-2004, 08:36 PM
wilson05's Avatar
re again
one more thing that i just read... you asked if it reved up in neutral???
well the way i understand it is that you think it revs up by itself ??? well it doesnt when i said revving up i just ment that i had pushed it to the floor it revs up then but not on its own
Old 11-29-2004, 09:10 PM
Well, based on what your saying here so far, it sounds like something he tranny. Id take it to the shop and have them check out the tranny and tell you if they think it needs a rebuild. The way I understand it, the fluid appears to be good yet it sounds like its slipping. If I had to guess based on this I would say the plates or something inside the tranny are bad.
Old 11-30-2004, 07:41 AM
wilson05's Avatar
Re: 69 Firebird loss of power
thanks i appreciate the help.... even though i dont want to have it towed to a shop i guess i'm going to if i ever want this baby no the road again
