Old 11-28-2004, 09:54 PM
Vtec95Civic Vtec95Civic is offline
Roll cages and 4/5-point harnesses..
Do they actually reduce costs of insurance? SOmeone told me this and I didn't know whether or not to believe it.
Old 11-28-2004, 10:05 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Roll cages and 4/5-point harnesses..
i dont think so. i know that some 4/5 point harnesses arent street legal because of the type of release they use. make sure you get one that is approved for street use in your state
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-29-2004, 01:42 AM
kjewer1 kjewer1 is offline
AF - Advisor
They dont reduce insurance as far as I know. They should though, bodily injury potential should be much less.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-29-2004, 02:41 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
well they only reduce potential body injury if installed properly. proper installation includes the use of a harness bar. if you tie the straps to the floor or any point lower than your shoulders the potential of breaking your back greatly increases
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 11-29-2004, 05:58 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
sparco makes a nice harness bar ,dont know if they have one for a dsm yet....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-29-2004, 11:47 PM
sparco doesn't make a harness bar for the dsm's yet. i've looked everywhere for one and the only person who makes 'em is http://www.dvdtfab.com the owner albert is badass and the reason he has em is cause he's a proud dsm owner as well.
