Old 11-28-2004, 09:20 PM
earlroots earlroots is offline
Red Hot Exhaust Manifolds!
1985 chevy G20 5.0L 4bbl quadrajet 3 spd trans.
ok the thing bogs under load and pops and exhaust comes out the carb. i did plugs wires cap rotor wires and fuel filter. then drove it with the doghouse off and noticed the top of the Y pipe and both manifolds getting cherry red hot. so i figured it was a plugged cat. replaced the cat and the problem is still there. i cant check the timing because when i unplug the 4 wire connector the thing won't start. when i unplug the 4 wire con. while van is running it dies. as of now i am stumped i have never seen manifolds get that hot before without any exhaust restriction. any suggestions??
Old 11-29-2004, 12:33 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Red Hot Exhaust Manifolds!
sounds like timing to me.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 11-29-2004, 01:04 PM
Riche Riche is offline
try a compression check. See if you have a bent valve.
Old 11-29-2004, 04:37 PM
Fireplug Fireplug is offline
Its running lean way to lean check the carb it might need rebuilt
Old 11-29-2004, 05:28 PM
Fireplug is correct. My answer would be the worst case. Start at the fuel filter on the carb. (inside the fuel line inlet fitting)
Old 12-11-2004, 09:20 PM
rrousou rrousou is offline
Seen this more often than I can remember.
I hate to say it but your going to have to replace the camshaft. The rear lobes are wore down ( weak spot on GM engines of that size) You can verify by pulling off the valve covers and cranking the engine and watching the valve train lift.
