Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-28-2004, 07:20 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Turbo sizing article(by me)
http://www.automotiveforums.com/vbul...=108747&page=7
The last post on the page. Tell me if you find any mistakes or should I say anything correct. I used this method to size the turbocharger on my car. It works!
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 11-30-2004, 12:54 PM
SaabJohan SaabJohan is offline
Re: Turbo sizing article(by me)
From a fast look I can tell you that your calculations of the temperature rise is incorrect. I think I have posted how to calculate that earlier.
Also note that it's common that there is a small pressure drop in the compressor inlet (due to the air filter and so on), this + pressure loss in the intercooler and tubing results in a slightly higher compression ratio than one might think.
When calculating flow though the engine one can start with the engine output, an engine typically requires somewhere around 3.5 to 4 kg air per kWh.
Using volumetric efficiency can be somewhat difficult to calculate with if one doesn't have any measured data. Typically VE is around 70 to 100% for a modern four valve engine, but racing engines can be have VE's of over 130%.
Old 11-30-2004, 08:51 PM
Zgringo Zgringo is offline
Re: Re: Turbo sizing article(by me)
Very good, I'm impressed to see someone has there ducks in a row.
Albert
Old 12-05-2004, 06:17 PM
454Casull 454Casull is offline
Not to nitpick or anything, but kWh is a unit of energy, not power (I assume by "output" you meant "power").
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-05-2004, 08:31 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
So, if 'power' is not energy... what is power? There is a direct conversion for kWh to HP. If anything, horsepower is the less sensical representation of 'power'. Torque(turning power) times RPM divided by 5252... who cares? Just give me a torque vs rpm graph.
Old 12-05-2004, 09:42 PM
240SX Guy
That is usually about 1-2psi combined correct? Considering most people who actually go through with this will have a high flow filter.
Roughly 10hp to every 1lb/min of airflow. Now do you calculate horsepower before the turbocharger is installed by multiplying existing output (in HP) by the pressure ratio? I used that method and it matched up with the 400m mph calculator.
Could you possibly measure this by output converted to airflow? Like my 146CID theoretically flows 16.2lb/min at 5600rpm where it makes 155hp. Now do 16.2/15.5 and get 1.04. So there is a VE of 96%? Please point me in the right direction if I am wrong. Thanks.
-Cory
12.6@122mph
Old 12-06-2004, 12:34 PM
BeEfCaKe BeEfCaKe is offline
Power is NOT energy.. Energy(Joules -->J) is obtained by integrating power(Watts--> W --> J/s).
kWh is a unit of ENERGY as you can see, because it too is in Joules.
Old 12-06-2004, 03:46 PM
duplox's Avatar
My bad, there is a conversion for kW to hp, not kwh... damn h. thanks for the clarification
Old 12-15-2004, 10:56 AM
To get a good indication of VE from engine power since we doesn't know the efficiency of the engine. We should however be able to estimate it with data on fuel flow and air fuel ratio (if the engine have been runned in a dyno earlier this data are typically known or can be calculated). Fuel from can be calculated from the injector size and the time they are open (it can also be corrected further for a more exact result).
The pressure losses seen over the intercooler and the air filter can vary, but in general they shouldn't be that high.
When estimating the power of a forced induction engine compared to the same engine without forced induction you must calculate the difference in density as seen in the intake manifold. So simply divide the absolute pressure with the absolute pressure as seen in the NA version (typically 1 bar), this can then be corrected by calculating the effect of the temperature rise caused by the compressor. If the intercooler is considered good enough this part can be skipped.
Old 12-15-2004, 05:03 PM
240SX Guy
Thanks.
-Cory
12.6@122mph
