Old 11-28-2004, 07:03 PM
Indyrider Indyrider is offline
94 astro u-joints
Has any one replaced their own u-joints? I did the rear one but the front ones are different. Whats up with the plastic pins? Thanks
Old 11-29-2004, 05:34 AM
CD Smalley CD Smalley is offline
Re: 94 astro u-joints
You can take a propane torch and hold it there to melt the plasitc out. It's not just a pin, it runs around the u-joint. They are a PITA. That's a factory u-joint if it's still got the plasic there. BTW, I would never replace just one u-joint, they are cheap, replace them both. Lastly, make sure you mark the drivesahft and pinion so that you get them back in the same way they cam out. Vibrations can happen if you get them back in out of phase.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-29-2004, 04:18 PM
Thanks for the info. BTW I would never replace just 1 u-joint either!
