Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 11-28-2004, 06:41 PM
cheboing cheboing is offline
valve or lifter noise
When i start my 84 fiero i hear noise that sounds like a valve or lifter . It goes away until the engine warms up and then i hear the ticking noise . Is there any kind of oil additive out there that might help stop the noise ? The car has only 105000 kms on it ... thanks .
Old 11-29-2004, 05:21 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: valve or lifter noise
Oil additives do nothing but hide the problem. At some point, the noisy component will fail, and it's usually a very dramatic, messy scene when it does.
Note that a VERY VERY VERY common issue on high milage (and some low mileage) 2.5L L4's is worn timing gears. The sound is similar to bad lifters but when listening cafefully, sounds more like raka-raka-raka instead of valve train tick-tick-tick. The sound comes from the timing cover on the crank pulley side of the engine instead of the tappet cover under the intake manifold. Timing gears, while high on the pain-in-the-ass list, can be replaced without pulling the engine.
Connecting rod failure was an issue on early model Fieros. While I doubt defective rods would have lasted 105,000KM, it's at least worth mentioning a bad rod goes knock-knock-knock and has bit of an echo to it.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
