Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-28-2004, 06:30 PM
beauburnett beauburnett is offline
350 Problems
i have a 1980 el camino with a 77 or so 350 in it. The car was running fine until one day it started cutting out really bad when i tried to accelerate. I replaced the spark plugs, timed the motor, cleaned the carburator, still doesnt run right. It seems like it is missing really bad, and it blows tons of white smoke out. Could it be the distributor? Any suggestions welcomed.
Old 11-29-2004, 07:51 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
White smoke means burning oil, so most likely, valve seals or rings.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 11-29-2004, 01:42 PM
well.....
the valve seals are kind of worn, but that doesnt explain the bogging down and missing........
Old 11-29-2004, 05:54 PM
suznine suznine is offline
350 problems
Have checked all your vacume lines?
Old 12-01-2004, 07:43 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: 350 Problems
Have you checked/replaced the fuel filter , not only the inline one but the one that is in the carb as well , where the fuel line screws into it ?
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 12-03-2004, 02:41 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 350 Problems
white smoke means water not oil, could be itake leaking antifreze
Old 12-05-2004, 09:13 AM
Off_Road's Avatar
Off_Road Off_Road is offline
Re: 350 Problems
dmbrisket 51 hit it right on the nose. White smoke is water. Black smoke is oil. Blown head gasket, cracked head, cracked manifold. Waters getting into the into the cylinder(s) somewhere. Get it fixed or you might be looking at a ring job also.
Old 12-05-2004, 06:00 PM
openheaders openheaders is offline
Re: 350 Problems
doesn't black smoke mean too rich and blue smoke is oil?
Old 12-05-2004, 07:00 PM
Off_Road's Avatar
Re: 350 Problems
Posted by openheaders - 12-05-2004 at 07:00 PMdoesn't black smoke mean too rich and blue smoke is oil?
You know, black, or blue, been so long I'm not really sure. I thought, black, dark blue kind of smoke did mean burning oil. Your probably right and I don't doubt you one bit. Been a few years since I've really been hands on with this stuff. And no it's not like riding a bicycle, you do forget (lol smiles). But I do remember white smoke is water, that's for sure.
Old 12-05-2004, 07:41 PM
turned out to be water in the gas.....few cans of heet later and i'm back on the road
Old 12-05-2004, 09:27 PM
Re: 350 Problems
white blue can be just burn off (to rich) black is bad, black is oil, it can varry due to you could have oil and be rich because of it
Old 12-05-2004, 09:29 PM
Re: 350 Problems
and its good to hear that it was only water in the tank you did the right thing although i dont go for the heet because the outlaw stuff treats more gallons per oz, either way if i can get heet cheeper i will
Old 12-06-2004, 08:11 AM
Off_Road's Avatar
Re: 350 Problems
If it's black or black/blue smoke. And we all agree black is oil.
Regarding a statement I have a question?
Posted by dmbrisket 51 - 12-05-2004 at 10:27 PMwhite blue can be just burn off (to rich) black is bad, black is oil, it can varry due to you could have oil and be rich because of it
If your burning oil (and of course depending upon the severity of the problem). But if your burning oil, a trail of black smoke. Which I would think must be fairly severe if you have a cloud of black smoke in your wake. Agreed?
So here's my question. How can you be rich at the same time? I mean, I would think if the problem is that severe you'd be lucky to even keep the engine running. The plugs would have to be oil fouled. The poor beast would probably barely be running, wouldn't it? So how could it be running rich also?
Unless, 2 complete seperate problems? They just both happen to occur at the sametime. Sounds like an Irish vehicle then (lol) would have to be.
Luck of the Irish.
Old 12-06-2004, 03:16 PM
Re: 350 Problems
depends on how your computer reads the oil burn off, and you are verry right if you burn rich with oil burn your not going far untill plugs are gummed up
Old 01-07-2005, 10:23 AM
TLA TLA is offline
Re: Re: 350 Problems
QUOTE=Off_Road]dmbrisket 51 hit it right on the nose. White smoke is water. Black smoke is oil. Blown head gasket, cracked head, cracked manifold. Waters getting into the into the cylinder(s) somewhere. Get it fixed or you might be looking at a ring job also.[/quote]
can someone tell me what is going on with my 350?
white smoke, water in the oil
had the heads rebuilt - one was cracked
put it back together and it did the same thing. so i put an intake on it. same thing. took heads back off and had them rechecked and they were good. help!!!!!
