Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-28-2004, 06:01 PM
Rupret Rupret is offline
2004 Daytime Running Lights
Has anyone disabled the daytime running lights on a 2004 Tacoma? I have read the Toyota Service Bulletin for 2000 (EL011-00). Has anything changed since 2000 and is it still an accurate disabling? Anyother ideas from anyone? I have also tried pulling the DRL fuse under the hood, but it did not have any effect the DRL at all. Thanks for any help anyone can provide.
Old 12-02-2004, 03:13 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
you will need to find the power wire for the drl's and splice in a toggle switch.
Old 12-02-2004, 04:02 PM
Re: 2004 Daytime Running Lights
Thanks for the info. Is that the wire the service bulletin advises to cut? Or do you know if there is another known wire out there?
Old 12-02-2004, 06:01 PM
i read it on here back in the summer, let me try and dig up the thread for ya.
Old 12-02-2004, 06:13 PM
couldnt find it dude.
Old 12-02-2004, 06:45 PM
Re: Re: 2004 Daytime Running Lights
Thanks for checking!
I think I'm going to try the wire mentioned in the service bulletin (www.yotatech.com/~corey/tech/ducky_drl/ducky.htm) this weekend, which was for the 2000 model, and I don't know if anything has changed since. I'll post a result, when I give it a try. I know I'm not the only out there trying to figure it out.
Old 12-02-2004, 07:37 PM
should be the same.
