'88 dl wont start... any ideas?
i have a '88 subaru dl, 98k on the clock, automatic.
im having a problem with it not starting, it's not getting spark. i checked for spark from the coil wire, and theres absolutely no spark. i had a fuel pump problem with my other car, and this problem with the Subaru sounds the same... it tries to turn over, crank, crank, crank, but wont start up. i cant exactly tell if the fuel pump is getting power, but the fuse is not blown and this hasnt been intermittent, it just stopped 3 days ago. car ran fine, no symptoms of a faulty fuel pump.... just now no spark. it had a starter problem and an alternator problem, which both parts were replaced and everything is ok with that. any ideas on what the problem could be with my car? also, LOVE the forum -gary |
Re: '88 dl wont start... any ideas?
Check the wiring of the igition system. You may have a faulty ignition switch.
![]() Support America's dependence on foreign oil - drive an SUV! "At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald. If you find my signature offensive - feel free to get a sense of humor. |
Check ignition amplifier...little black thing on the coil bracket
check and clean all grounds did you check timing belts? plug the 2 little green plugs (located near left hood hinge) together and turn on the key and your fuel pump should cycle on and off. for good suby info go to www.ultimatesubaru.net and check there forums |
take the distributor cap off and see if the rotor turns when you crank the engine. if it doesnt turn you have a broken timing belt. the timing belts are supposed to be changed at 60k and every 60 k after.
if the rotor is turning suspect the crank angle sensor. try pyulling the engine codes. the Haynes Manual for subaru 1600 and 1800 is very good and has the code procedure
I invented the TrashWagon. 83 GL wagon, originally yellow, ea81, 2wd 5wpd now it has an ea82 motor, a 5spd dual range 4wd transmission, ea82 front suspension and rear isc brakes sheetmetal body armor, and krylon paint job shag carpet interior, and a stereo system mounted on the ceiling "roof of Boom" [email protected] come see http://usmb.ultimatesubaru.net |
