| Off-Topic Talk about anything other than cars. |
Caliper
I was just wonderin what 2g Eclipses out there use 2 piston calipers. I heard that the 2g turbo has them but would it be the GS-T or GSX. Any info of what 2g eclipse has the 2 piston calipers would be greatly apprciated.
T.I.A Last edited by Str8in; 11-28-2004 at 05:30 PM. |
I believe that would be caliper.
Re: Capilaries
happy now?
Re: Re: Capilaries
I got excited--I thought this thread was about someone who bled to death
1996 Eagle Talon |
Re: Re: Re: Capilaries
those are always good stories
![]() If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires 2007 Trailblazer - stock 97 GS-T -> lots of mods 98 GS ->total loss, now being parted out |
Re: Capilaries
I believe all 2G AWDs had the front "big brakes." There should be no difference. The rears do differ though, starting mid 95 if I remember correctly. Still the same calipers IIRC, but different rotors. I have no idea about FWDs but I might expect them to be the same, and I have even less of an idea about the NTs. Pretty much garanteed to be smaller though naturally.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Capilaries
The turbo FWD's have all around disk brakes too...not sure if there the same as the AWD models tho...
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: Capilaries
i know that the 98 awd have doble piston disk brakes, and the 95 fwd have single piston disk brakes. i did learn this after i through away the front brakes of my tsi awd now i have to find new one for my project.
Diego Fontán Eclipse GS-t ==>AWD 12.12 @ 113.xxmph 60' 1.76 ![]() Check My GS-T ==> AWD project car's video: http://cssteam.com/gstx.wmv At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm |
