Old 11-28-2004, 03:27 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Pinging with correct ignition timing
I adjusted the ignition timing on my car and when adjusted to the center red mark on the crankshaft, the car pings like hell. So I set it back to where there were two little red dots on my dizzy, now it stops. But why does it ping when it's adjusted properly? Does that mean my timing belt has skipped a tooth or something?
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 12-04-2004, 07:01 PM
Shaguar47's Avatar
Re: Pinging with correct ignition timing
bump
Old 12-04-2004, 07:31 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
the pinging is caused by it being too far advanced, probably jumped a tooth or something, If it smooths out by adjusting the dizzy just leave it like that.
Old 12-04-2004, 07:47 PM
Shaguar47's Avatar
so running with it off the timing mark is okay?
Old 12-04-2004, 07:52 PM
Forunn Daberator
You might loose a little power or maby gain a little power due to the valves opening at a slightly differnt time, but it physically wont hurt the motor. If your bored and stuff pull it off and try it again, if you've got stuff to do it wont hurt anything to put it off till another time.
Old 12-04-2004, 07:54 PM
Beater88 Beater88 is offline
Umm...If it jumped a tooth I would really check out why to be safe. The belt could be streched or you may have a bad idler arm. Eather way if it snaps you have a boat anchor.
And no just changing the timing will not fix the issue as the valve timing would be off. But it wouldnt hurt anything.
Old 12-05-2004, 09:12 AM
Shaguar47's Avatar
The only thing I can't get is that there is a line stenciled on the metal tab, above the top dizzy bolt and when I got it, both sides where lined up, but with the correct timing there off. WTF?
Well, I guess I'll go put it back to the line. thanks
