Old 11-28-2004, 03:18 PM
davez34 davez34 is offline
My car is dieseling (1994 Lumina Z34)
Hello,
I just got the computer replaced because it had gone bad. The mechanic showed me, with the tap test (hitting the computer), the engine would stall out. I told him to go ahead and replace my computer, and everything seemed great. Now, sometimes, if I drive around for a while, my car will diesel for sometimes up to 30 seconds after I take the key out of the ignition. I know this is not good, and the people that replaced my computer said they don't know what it could be. Does anyone have an opinion on the problem? Should I change out my spark plugs? My car has 135 k miles on it.
Thank you.
Old 11-28-2004, 04:43 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: My car is dieseling (1994 Lumina Z34)
could the timing be off? Does it run normally well when just driving it? I would say to just give it a week or two to let that new computer "relearn" all its parameters. Wait it out. Good luck
Old 11-29-2004, 07:29 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
That IS wierd, since dieseling is caused by fuel being ignited by abnormal cylinder temps, coupled with unchecked fuel flow. In theory, a fuel-injected engine shouldn't be able to do it, since the injectors and fuel pump are dead once the key is off, therefore there would be no fuel present to run-on with. I can't even begin to have an answer for this.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-29-2004, 03:59 PM
tblake's Avatar
In God We Trust
maybe try instaed of 87 octane, try 89, or 91, thats what is said to help a carb car keep from dieseling, but, I dont know.
Old 11-29-2004, 05:16 PM
cadgear's Avatar
cadgear cadgear is offline
Maybe a leaking injector or injectors? After the key is off pressure will be slowly bled off...but I hooked up a tech2 to my car and disabled the fuel pump, it only ran maybe 5-7 seconds, not nearly 30. Check pump relay, ignition components...hm. That's quite weird.
Old 11-29-2004, 05:26 PM
Fireplug Fireplug is offline
Was the prom replaced with a new 1 or did they reuse the old prom from the old pcm. I would remove the neg battery cable for about 5 mins then reconnect it and take it for a long drive to help the pcm relearn. The 3.4 is a good engine but hard to work on and you dont want to break the timming chain tensioner by having engine after run
Old 11-29-2004, 08:26 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
Deiseling?!?!?!? How the...
Its a feul injected car, feul injected cars shouldnt deisel...
that is really weird.
Thats beyond me. I dont see how it could do that unless there were some serious wiring problems under the dash and hood of that car.
