Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 11-28-2004, 01:03 PM
panchoman's Avatar
panchoman panchoman is offline
Send a message via AIM to panchoman Send a message via MSN to panchoman Send a message via Yahoo to panchoman
lowering the idle
how would u lower the idle on a 94 nissan pick up, nothing seems to be wrong it just idles too high what can be done to lower it?
thanx
"Hasta la victoria siempre!"-Ernesto "Che" Guevara
Old 11-30-2004, 01:26 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
should be a Idle Air Control Valve which has a phillips screw on one side of it. that screw contols idle speed. also, you can adjust the TPS sensor to lower or higher idle. but if you adjust the TPS sensor to much, the car will feel sluggish.
good luck...
ZedEx Crew Member #4
