Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-28-2004, 12:31 PM
CAMPSITE88 CAMPSITE88 is offline
2001 Durango Is Skipping
I have a 2001 Dodge Durango that is skipping. I have changed the plugs, wires and rotor cap. The strange thing about this problem is it is intermitent. It skips sometimes. It usually does not do this immediately. I can go several miles before it starts.
Any suggestions would greatly be appreciated.
Old 12-29-2004, 03:47 PM
xxxx JD xxxx xxxx JD xxxx is offline
Send a message via AIM to xxxx JD xxxx Send a message via MSN to xxxx JD xxxx Send a message via Yahoo to xxxx JD xxxx
Re: 2001 Durango Is Skipping
I recently had the same problem. I have a '01 5.9L R/T w/ 60,000 miles on it. I took it in originally because it was skipping. We put a new Distributor, Rotor, Wires, Plugs, etc on it. Ran great for about a week, then starting doing the same thing again. Took it in and the #1 Plug was flattened. This was cause by the rod I believe hitting it. Needless to say it is getting a new motor. Might be worth having the motor's insides checked out.
Old 12-30-2004, 02:15 PM
x3mtm's Avatar
x3mtm x3mtm is offline
Send a message via AIM to x3mtm
hey mine kinda has the same prob.. after u drive it a long time... it kinda skips......i think it might be the throttle position sensor....might wanna check it out...L8R
