Go Back   Automotive Forums Car Chat > Honda > Prelude
View Poll Results: Is adjusting the sell price fair?
Yes 0 0%
No 0 0%
Maybe 1 100.00%
Voters: 1. You may not vote on this poll
Old 11-28-2004, 10:49 AM
jackcassid jackcassid is offline
ABS Light????
I`ve got a 96 Si.Recently the ABS light is coming on after driving a few yards,but not at startup.Does this sound like a wheel sensor?Once it comes on,it won`t go off.Should I try resetting the ecu?The fluid level is fine.I`m trying to sell this car,and I need to get this fixed asap.I`ve already dropped the price $900 in light of this problem.Please help!!!!
Old 11-28-2004, 11:22 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
im willing to bet its a wheel speed sensor... i dont know if a parts store can pull abs codes or not... maybe take it to ahonda dealer and have them check it...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 11-28-2004, 01:04 PM
Abs Light..
This car is a must sell...I don`t want to sink a ton of cash in this thing...Can a tire and brake guy fix this?...Nearest Honda dealer is 40 miles away.
Old 11-29-2004, 04:08 PM
ludegal ludegal is offline
hey..i hope you get this soon...did you check the break fluid....i have a 92 prelude and it was the break fluid that caused the ABS break light to come on...almost ruined some stuff by not having it in there....lemme know if this works....p.s. fill it up...pump the breaks..drive around a little and then fill it up again.....it will take day of driving for it to realize youve refilled the fluid.
Old 11-29-2004, 06:47 PM
gunnmen01's Avatar
yeah i tire guy could fix it but you still need to know which wheel speed sensor and you have to get the sensor.... you can prolly get them online
gunnmen01
Old 12-02-2004, 09:34 AM
Dyonisis Dyonisis is offline
Send a message via AIM to Dyonisis Send a message via Yahoo to Dyonisis
Well,
I recently had this problem, except mine would come on and off intermittantly sometimes would stay on for days at a time. Mine turned out to be a float. Maybe this could be your problem too.
Old 12-02-2004, 12:46 PM
Re: ABS Light????
Originally Posted by Dyonisis
Well,
Float?Where is this?
Old 12-03-2004, 12:10 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: ABS Light????
I have the exact same problem with ABS. I never bothered to investigate it since I don't need ABS, but I have always presumed that there was a problem with the ABS unit in the engine bay.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 12-04-2004, 08:08 AM
Re: Re: ABS Light????
I had the codes pulled.It was a 4-1.If I am right,this is a front right wheel speed sensor.I found one on the net for 63 dollars.How hard is this to do?Do I reset the system?And How?
Old 12-04-2004, 04:51 PM
gunnmen01's Avatar
its pretty straight forward, take your wheel off and start unbolting the 10 mm bolts that hold the wheel sensor on, just follow it back up the knuckle to the plug... rebolt the new one one and plug it in, then unhook the battery to reset the system and your done.....
gunnmen01
Old 12-04-2004, 04:55 PM
Re: ABS Light????
Thanx alot!Invaluable info can be found here!
Old 01-05-2005, 01:26 PM
nudelude nudelude is offline
Re: ABS Light????
hm.. mine has been on for a long time... i should try these suggestions...
