Old 11-27-2004, 10:12 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Question what laptop for dsmlink
ok got my dsmlink back now im stuck, i have no clue what laptop to buy and if i get the right one , and i know dsmlink explains a little but i am lost. so if sombody can tell me what they use if they have dsmlink thas be great
Old 11-28-2004, 03:46 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: what laptop for dsmlink
The IBM Thinkpad 380 XD P233 comes with everything needed for dsmlink, plus a little extra memory (which is always a plus). They go for about $100 on ebay. It's the laptop I've bought to use with dsmlink very soon.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-28-2004, 04:31 AM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
i plan to be running DSM Link when i get the GS-T on a compaq persario 1245. if i need some serious power i'll use my sony vaio grv670.
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 11-28-2004, 12:50 PM
o*HeR()'s Avatar
Banned
kool thanks alot
Old 11-28-2004, 01:08 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
A laptop is a laptop. Get something with the minimum requirements. Won't cost much.
Old 11-28-2004, 01:15 PM
o*HeR()'s Avatar
Banned
well i just cant seem to find a laptop besides the think pad with an r232 db9 serial interface port , and dsmlink said that you can use a usb to rs232 adaptor but its female and the cable that thet dsmlink looks female to so im gonna go to a computer fair this weeken with cable in hand and im just gonna start plugging it into to stuff see if it will fit
Old 11-28-2004, 02:34 PM
kjewer1 kjewer1 is offline
AF - Advisor
No modern laptops come with serial ports it seems. You end up with said USB to serial adapter. The DSMlink forums give some examples of ones known to work and how to use them. I've perosnaly used some old POS laptops, one was about 200 mhz. Works perfectly. DSMlink doesnt require much to run at all. The ECU is doing all the work, the laptop is just listening in.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-28-2004, 02:47 PM
o*HeR()'s Avatar
Banned
Re: Re: what laptop for dsmlink
well thats what im going to look for at the pc fair an old laptop like 95 maybe lower
Old 11-28-2004, 07:33 PM
you want 98 or higher. if you want to use alot of stuff. microsoft windows 95 and 98 first edition won't even support usb devices. so i would suggest a laptop thats say 3 or 4 years old has the serial ports. if not a laptop running windows 98 second edition with usb will work. the pcimia slot for say wireless networking cards will have a card to serial poet as well. i don't know if they have an rj-45 to serial tho. just get say a laptop from like 1998- 2000. my persario 1245 came out like 4 or 5 years ago and it has a db9 connector. try a search for a compaq persaio 1245 on ebay. that will work plus if you need more ram it has an upgrade bay for it
Old 11-28-2004, 09:57 PM
The laptop I suggested sells on ebay for ~$100, and it has everything DSMlink needs, INCLUDING windows 98 already on the computer if you buy from the seller kjo3 - he sells computers PERFECT for dsmlink. Here's a link... http://cgi.ebay.com/ws/eBayISAPI.dll...725453747&rd=1
95 GSX
Old 11-28-2004, 10:08 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
nice PC , i have built acouple computers and i was thinking of building like a black box with dsmlink on it to put under the seat...then buy alittle monitor to put in the glove box or somthing...and have dsm link in car at all times...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-29-2004, 01:41 AM
AF - Advisor
There are two poeple locally that have in car PCs. Both have gutted the factory radio and put the PC components in that. One has a 15" LCD flatscreen, the other has a 7" touch screen, both mounted right on the dash. There are threads with pics and info on www.racingknowledge.com.
Kevin Jewer
Old 11-30-2004, 10:13 PM
DsManiac's Avatar
DsManiac DsManiac is offline
Banned
would this have a db9 serial port? http://cgi.ebay.com/ws/eBayISAPI.dll...725079647&rd=1
Old 11-30-2004, 11:28 PM
yea its the same laptop i have
Old 11-30-2004, 11:33 PM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Really the OS should not be a factor when buying yourself a laptop. Just find one with the port your looking for, and just look at the specs. I am sure that you could find something that can do the job for about $150.
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
