Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-27-2004, 06:50 PM
bigbob bigbob is offline
rpm
what is the highest {safe} rpm to rev at? i want to build a supercharged setup on a 95. 5.0ho and was thinking of chanign the revlimiter to 7,000 so the car gets the most out of the high end power. and then i can use track heat intake, and stageII cam is that guna be safe
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-27-2004, 08:58 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: rpm
your powerband is determined by cam specs, header primary length, intake runner length, and a few other little things. you can't just change your rev limiter without any knowlege and expect it to be right. get in touch with trick flow and ask them what the ideal shift point is with that cam and intake. then set your rev limit a few hundred rpm higher than that.
also, if you plan on spinning your motor to 7 grand you need to reinforce your bottom end. you'll put a rod through the pan or lose the tops of your pistons if you regularly spin that high on the stock bottom end.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 11-28-2004, 03:06 AM
NIN881 NIN881 is offline
Re: rpm
You just need to find where you power peak is and that is all i would go. If it is a track car then I would get a differtent block If I spun it that high. I have tfs heads and shift at 6000 with a stock cam. it make decent power and a super would make it a rocket.
1994 Mustang GT, TFS TW heads, TFS street heat intake, Pro 5.0 shifter, BBK LT headers, BBK short off road H, Mangnaflow catback, FMS 3.55 gears, TFS 1.6 rr, JMS chip (soon to be replaced by a tweecer).
Horsepower sells cars, torque wins races.
Old 11-28-2004, 09:40 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: rpm
Stock block with a power adder won't last long under that abuse. Sportsman or better.
When you build the motor, be sure to polish the crank and rods and use a good set of lightweight forged pistons. SRP and DSS pro-lites are what I've been recommended. JE's are heavier pistons. I'd look into DSS's Long Rod 306 kit if I was you, a stock 302's rod ratio isn't too conducive to high RPM...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
