abs light is on??
when i brake under 10 mph the abs light comes on and the brakes studder a littleand pulsat.i just changed all the brakes and rotors 5 days ago .i could use some help thank you.
Re: abs light is on??
Sounds like the ABS system was kicking in.
Was the road slippery when it happened?
1995 Factory Blazer Service Manual for sale, PM if interested. |
,no it was sunny and dry out.i pulled the fuse so i am running on my regular brakes till i have enough money to go put it on the computure you know.I spent over $800 on the 4 brakes,rotors,alternator,battery.
Sometimes the speed sensor on the front wheels have been known to get dirty and need to be cleaned and reinstalled.
In mine the other day, I was pulling up to a stop sign I hit a little slippery spot, the ABS kicked in and now the light is on permenently and the ABS wont work at all?
Im pretty sure this is the first time since I have been driving the thing that the ABS has even come on. Would dirty sensors cause the system to totally shut down? |
Yip, it would, try resetting your computer and it should be good.
If it comes back, you will ned to clean the speed sensors on both front hubs.
i've also heard that if the lights on the computer might have goten shocked and if you speed up to 60 mph and nobody around and you slam the brakes that it will skid and then the ABS will kick in will be fine. do at your own risk. i've never had the problem but my ABS comes on all the time from driving. never had it stuck on.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system. 71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out. 90 cav, 2.2 tbi, gas getter. 99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed. |
