Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 11-27-2004, 03:27 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
soldering/brazing
In reply to the thread about soldering joints to make a gokart, you could always use fittings to join the tubes, and braze them. It's pretty much teh same thing as soldering, but it holds a much stronger joint. It's not ultimately as strong as a properly welded joint, and it weighs a little bit more, but you can do it in your garage with a torch. Butane won't nearly be hot enough, but you can get a cheap turbo torch for about $30 with a bottle of MPS gas, which would be enough heat for soldering the joints, or you can get a small oxy-acetylene welding/brazing kit for about $70 and that would work for the brazing.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 12-13-2004, 09:07 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: soldering/brazing
Whoa, somebody actually suggesting using Gas....
(just kidding)
Not many people know how to braze anymore, much less do it...
