Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-27-2004, 04:22 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Unhappy Take off Door Handles..How??
About 7 months ago, i taped off, and masked my doors with plastic garbage bag so i could spray my handles black, then do a clear coat.
Now, i want to do it again, but i want to take off my door handles to do a much better job (sand/prep etc..). How is this done? I already took off my door panels, and there is no access to taking off the *outside* handles.. Am i missing something?
Please help if you could, thanks.
Old 11-28-2004, 05:31 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Take off Door Handles..How??
97's are held on by two blind rivets. Lift up on the handle and look up behind it. Prop up the handle with a 1/2 inch by 4 inch dowel and knock out the center pin of each rivet. Then use a 1/4 inch drill to drill out the rivets being careful not to enlarge the holes in the door skin. Replace the rivets with Ford part number N805945-S102. Check to see if this part number is the same for your yearBird.
Old 11-28-2004, 05:38 PM
Thanks 97bird, last nite i just taped off the both sections, and did a decent job of spraying/clear coating them.
Now that i know that, about the rivets, i'll give that a try in about a couple months when the paint looks non-new again.
